after market light help
Was looking for an HID set up and found the Recon's at a great price but the bulbs are simply not bright enough....think stock. Anyway, I purchased some brighter bulbs for the stock housing and switched them out again. This time they shine far enough out and don't give that super white light that I can't stand (personal preference). But the complication is that I have the other set up and really like them. So, if any of you have experience can you tell me if there are "upgrades" for the Recon set up? Here's what I have:
well I called Recon and the guy told me that each HID is specific to the ballast they sell so it's $250 to do the upgrade on the projector bulb. Mind you these come with bulbs already but the low beams simply suck. So they told me I could use these RECON Part # 264H1HID - H1 HID High Intensity Discharge Off-Road Lights
Problem is I don't want the ballast just the bulb so did the guy at Recon tell me the truth? Also, any other alternatives for this?
If you are asking if bulbs and ballasts are specifically matched, I have swapped bulbs and/or ballasts in previous vehicles without issue. If you are asking if you can put an HID bulb in with no ballast, the answer is no. Perhaps things have changed with HID in the 3 years since I've messed with them though. Good luck with your hunt! Hope that helps.
I know I need the ballast and in fact they are already installed. I just want to replace the projector bulbs pictured above for more light and they wont sell them without the ballast. I think they are giving me the run around as I've never heard of having to match the ballast to the bulb.
