Power Windows - Ford Truck Enthusiasts Forums
Power Windows
Old 08-02-2014, 10:52 PM
Loafer Loafer is offline
Loafer is starting off with a positive reputation.
Power Windows
I need some help. I have an 89 Bronco and a 91 F150 short bed both have power windows. The problem I have is if the windows are rolled down all the way the motor will bind up and you must remove the door panel and (tap)hit the motor a few times to free them.I've even had to take the wholr regulater out to free them up. this is getting very frustsrating. Any help will be appreciated.This happens on a weekley basis as my wife drives one and my son drives the other and neither one knows the meaning of DON'T ROLL THE WINDOW ALL THE WAY DOWN !!
Old 08-03-2014, 08:55 AM
Eddiec1564 Eddiec1564 is offline
Eddiec1564 has a very good reputation on FTE.Eddiec1564 has a very good reputation on FTE.Eddiec1564 has a very good reputation on FTE.Eddiec1564 has a very good reputation on FTE.
Ahh, the ole window jammed down problem.
What is happening to cause that problem is the inside door panel will bow out when the window is fully down. That will bind up the power window regulator and stalls the motor out.
I have not really looked into my issue with the pass side window, but I think there's a track stop that is missing/broken that allows the window to drop down farther, jamming the regulator.
Few weeks ago there was a thread about this problem, I haven't heard anything yet about a fix.
Old 08-03-2014, 04:01 PM
I have looked at all the window tracks I can't seem to find anything is broken or missing I have noticed that there is this a little round stub out on the regular and once window goes all away down that stub is up against the track but I don't know if that's what's causing these to bind up any further help would be greatly appreciated
Old 08-04-2014, 10:17 PM
Can you post a photo of that stub? I just can't remember seeing that on my truck. I'll probably have to take it apart again to see as today I rolled the pass side window all the way down again..... A lucky smack got it to go back up!
help me diagnosis electric window GuitarJesus 1987 - 1996 F150 & Larger F-Series Trucks 3 02-24-2014 09:18 AM
Rear Window Binding Crew Cab 1994F2507.3L 1994.5 - 1997 7.3L Power Stroke Diesel 3 02-18-2014 08:27 AM
Power window issue teamlx88 Expedition & Navigator 4 02-02-2014 04:34 PM
Manually roll up power windows??? richrock Explorer, Sport Trac, Mountaineer & Aviator 9 05-27-2005 09:43 PM
Failing or weak power window in 93 Explorer wickware Explorer, Sport Trac, Mountaineer & Aviator 14 09-15-2004 03:33 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
