Still a little fuzzy on disc brake swap
I am now the proud owner of a 67 F100 4x4. I'm getting into planning for my build and looking at a disc brake swap. I still can't quite figure out the details, there is so much info on here I might be on overload status.
Ford_Six states:
For 4x4 trucks, there are a few different ways to go. For F-100 trucks, you can use GM D44 outers, rotors, and calipers.
I guess the problem is I don't know enough about the actual axle. What makes a Dana 44? Are they all the same out to the knuckles or how does that work? When he refers to "outers", what is that? I have tried to find a diagram online that explains the parts of a D44, but no luck.
Once I figure out what outers constist of, do I just need to find any vehicle that uses a d44 and has disc brakes to rob parts from?
I appreciate the patience. I usually try to avoid forums because of attitudes, but this one seems to be different.
Ford_Six states:
on
You need some education. Here is an article referenced by Wiki on the Dana 44. You could use all Ford parts for a brake swap or just swap in a complete Dent 76-79 axle. Dana 44 Solid Front Axle: Part 1 Reverse Spiral Housing
on
Yea you need to do a lot of reading before you jump in over your head and get parts that won't work. Dana makes front & rear-ends for most vehicles.
Jeep, chevy scouts fords and so on.. Some of the small parts will interchange. Some have the driveline on the left & some on the right.
Some guy go with aftermarket disc brake kit setups.
Read & read read some more this is home work.. Go on other sites and learn what you can.
Orich
Orich
captbo
01-12-2011 07:32 AM
jackslater
04-27-2006 02:35 PM
kmusmc
09-26-2005 11:56 AM
