1990 Ford F-150 radio help!
08-02-2014, 04:55 PM
on
Recently my radio won't turn on at all when u turn on the key. Everything else works. Could it be a ground cause it's acting like it isn't getting power.
08-02-2014, 05:08 PM
on
My radio did the same thing, turned out to be a bad radio. But you could pull it out and see if the connections are good. Is it an aftermarket radio or factory?
Tanner
08-02-2014, 08:08 PM
on
It's an aftermarket stereo . I had an aftermarket stereo in their before and it suddenly started not working so I thought it was the head unit so I bought a new one and it's not working so I'm not sure where to start looking for problems
08-03-2014, 09:15 AM
did you check the fuses and ground connections?
08-03-2014, 10:25 AM
on
I've checked the fuses. I have been ttrying to find out where the chassis ground is for the stereo stuff but I don't know where the ground wire leads
08-03-2014, 10:54 AM
1995 ford
Aftermarket Products
12-20-2016 01:43 PM
street131
03-12-2011 09:31 PM
Sayer Lane
06-28-2009 01:59 PM
Stymie
07-26-2002 08:28 PM
