Fuse 13, brake light keeps popping - Page 2 - Ford Truck Enthusiasts Forums
Old 08-03-2014, 01:35 PM
CraigK's Avatar
CraigK CraigK is offline
CraigK is starting off with a positive reputation.
I found the problem.
A few years ago I ran a wire from under the master cylinder to the back of the truck for the center stop light on my camper shell. I don't know why from there but if I remember there was a label that said 'center stop light' or something like that.
Anyway I ran it along the loom and zip tied it along the way to the back. It looks like that wire got caught in the tank strap when I tightened up the new tank. I cut the snag and now no more short.
Thanks for the help!
Old 08-03-2014, 01:39 PM
danr1 danr1 is offline
danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.
LOL yea that was going to be next, high mount brake light back of cab.
Suggested rabs first as you stated the light was on.
Glad you found it, mystery solved.
Old 08-04-2014, 10:48 AM
1995F150XLT4x4's Avatar
1995F150XLT4x4 1995F150XLT4x4 is offline
1995F150XLT4x4 is gaining momentum as a positive member of FTE.
Awesome, glad to hear that!
1986 vs 1987 fuel gauge sender ohm values baverwolf 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 03-13-2016 12:22 PM
Fuel Gauge SNAFU - Where Is Rear Tank Ground Wire? Fixnstuff Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 18 11-16-2015 07:15 PM
1988 E250 with 351. Fuse popping when selecting front tank skippermccoy 1987 - 1996 F150 & Larger F-Series Trucks 0 09-09-2015 02:01 PM
Fuel sender/pump question walt1968 1994.5 - 1997 7.3L Power Stroke Diesel 2 08-15-2014 09:59 PM
87 F250 460 Fuel puzzle sitdog84 1987 - 1996 F150 & Larger F-Series Trucks 12 05-28-2014 02:44 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
