Need help - Ford Truck Enthusiasts Forums
Need help
Old 08-02-2014, 02:30 PM
87f150mudder's Avatar
87f150mudder 87f150mudder is offline
87f150mudder is starting off with a positive reputation.
Exclamation Need help
Ok I'm haveing lots of trouble with my truck no clue what's wrong with it but I'll list the symptoms
Ideals at 1500rpms
At full throttle it will only climb to 3000rpms
Going uphill at all I have to put the truck in second gear to avoid stalling
Truck sounds like it is skipping I thinking that's just a spark plug went out though
Old 08-02-2014, 05:47 PM
1995F150XLT4x4's Avatar
1995F150XLT4x4 1995F150XLT4x4 is offline
1995F150XLT4x4 is gaining momentum as a positive member of FTE.
Can you explain to us when these things started happening and in what order? Have you done any repairs to the truck recently or did anything bad happen while driving/off roading?
Old 08-02-2014, 08:49 PM
Ddaybc's Avatar
Ddaybc Ddaybc is offline
Ddaybc is starting off with a positive reputation.
Have you pulled the codes? That's the first place to start. You have multiple symptoms but you may only have one thing going on. Getting any codes is the first thing to do.
Old 08-03-2014, 09:31 AM
Quote:
Ok we'll my dad got this truck two years ago and it's never left my yard since we bought the truck it's been one problem after another I'm more a chevy guy then a ford guy but this truck is pos Iv put a head gasket on it new manifolds new intake new injectors fluid change and the truck has never ran right il fix one thing and it gains 3 new problems and to top it all off the wiring is butchered and makes check engine lights throw 24/7
Old 08-03-2014, 10:24 AM
timbersteel's Avatar
timbersteel timbersteel is online now
timbersteel has a good reputation on FTE.timbersteel has a good reputation on FTE.
That's terrible someone butchered the wiring. All I can say is, start with basics.
1. Pull codes.
2. Check fuel pressure.
3. Get a Chilton or Haynes manual. Either or both is still far better than nothing at all. Most generally, both cover what is needed to do diagnostic checks and general info regarding fuel and electrical.
4. Address problems one at a time and PROGRESS.
5. Post each problem with corresponding checks.
6. Use the Search function or Google corresponding problems for other problems members here or elsewhere have encountered.
7. If all else fails, consider parting it out. You'll come out better $$$ than selling or scraping.
Acceleration problem s Big_Z88 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 04-05-2016 09:57 AM
Turbo malfunctioning when hot matieenterprise 6.0L Power Stroke Diesel 20 08-15-2015 03:45 PM
Idling at 1500 rpms.. HELP Jonathan Stone Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 2 07-29-2015 01:29 PM
Truck jerks around 50-55 at 1100 rpms and again right at 80. JstoneF150 2004 - 2008 F150 3 02-19-2015 09:57 AM
04 250 diesel. Truck jerking in low Rpms. alexisvfd 6.0L Power Stroke Diesel 9 09-22-2011 05:01 PM
Tags
300 4.9l, 300 6cyl, 300-6, ford, rpm, timing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
