Recommendations - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Recommendations
Old 08-02-2014, 01:44 PM
03GRS 03GRS is offline
03GRS is starting off with a positive reputation.
Recommendations
Hi all:
I'll be replacing the coil packs and plugs on my 03 4.6L Expedition. Any recommendations for either part? I'd like to use quality parts, but not necessarily break the bank.
Thanks in advance.
Old 08-02-2014, 02:10 PM
xSgtRenegadex xSgtRenegadex is offline
xSgtRenegadex is starting off with a positive reputation.
Motorcraft plugs. Unless you are looking for higher performance. Again unless you are looking for higher performance I wouldnt change the packs unless there is something wrong with them, those get rather expensive. Do you have a 2 or 3 valve motor?
Old 08-02-2014, 04:06 PM
Hi xSgt..
Thanks for the response. Coils are ready to be changed...so they have to go. And I have the 2 valve Romeo.
Old 08-02-2014, 04:12 PM
r2millers's Avatar
r2millers r2millers is online now
r2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud of
Quote:
Originally Posted by 03GRS View Post
Hi xSgt..
What makes you think the coils are ready to go bad? They either work or don't, no in between.
If you don't want to "break the bank", just change the plugs with good plugs as noted above.
No reason to spend a dime on CP's until necessary. Even though mines a 5.4, I've changed two individual units in 317,000 miles.
Old 08-02-2014, 04:38 PM
CPs are $100 easy per cylinder. Motorcraft iridium are quality plugs.
Old 08-02-2014, 05:09 PM
alwaysfords41's Avatar
alwaysfords41 alwaysfords41 is offline
alwaysfords41 is gaining momentum as a positive member of FTE.
Rock Auto has Motorcraft coils for $42 per, a dealer will hit you for 75-90 for the same part. They have economy versions also. You can find them on eBay for as low as $8 each.
Old 08-02-2014, 05:18 PM
Thanks for all the responses. I'm going to rethink changing the cops. I'm getting a missfire (haven't pulled a code yet, was planning to have the code checked at the store) and with 134K on the truck, I just figured it was time for new cops.
Old 08-02-2014, 07:03 PM
Probably time for one. See what the code says and change that one.
Old 08-03-2014, 06:26 PM
Code came up p0300. That code has a list as long as your arm on the root cause. So...before I start dropping a lot of coin on new COP..plugs etc., lets just start out with cleaning the MAF sensor. From there will be checking vacuum hoses, egr valve and so on. Hopefully it's something simple.
The missfire code (p174) said it was random cylinders, not one specific cylinder.
Anyway, I'll post a report later on whether or not the MAF cleaning helps.
Again, thank you all for your responses.
Glenn
Old 08-03-2014, 06:32 PM
Normally P0174 is accompanied with P0171 which is a Bank 1& 2 lean...not a misfire
Old 08-04-2014, 04:26 AM
alloro alloro is online now
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
Was it a P300 or a P174 code that you got?
Old 08-04-2014, 06:33 AM
tseekins's Avatar
tseekins tseekins is offline
tseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputation
I had a misfire on mine a couple years ago and my autozone code reader was pointing me towards a bank one lean issue. Turned out to be a cracked vacuum hose. I was convinced it was a bad COP so I bought one as a spare and it still sits in my tool box unopened.
Old 08-09-2014, 06:07 PM
Hi again...
Well I had both the 0300 and 0174 codes. 174 is the lean code correct? I've started with cleaning the MAF sensor..that helped somewhat but still not right.
So, before I start messing with COP and plugs, I thought I'd start with vacuum lines etc. The inexpensive stuff, plus with the age of the truck, the vacuum lines probably are starting to dry out.
The truck has been parked now..I really don't want to drive it with the light on, so sunday I'll start with the vacuum lines/PCV valve and related grommet.
Any other suggestions would be appreciated.
Thanks again.
Old 08-09-2014, 09:14 PM
The P0300 code means you're getting misfires on multiple cylinders. These misfires in turn cause the P0174 code. So your first step is to find and fix the misfires.
Old 08-09-2014, 10:57 PM
Hi Alloro...I was told that if there was a bad vacuum, PCV valve, etc that the PCM would lean out the engine, causing the misfires. This is why I first started with the vacuum lines before I jumped into either the COPS or plugs etc.
I've changed the PCV valve..the old one was pretty gunked up and the truck runs better, but it isn't running as it should.
One step at a time, I guess.
Thank you for your response, I do appreciate your time.
Edit: I did clean the MAF sensor..that too helped a bit.
'03 v10 y-pipe, good or bad??? nunomad Modular V10 (6.8l) 44 08-29-2016 10:56 AM
Trans cooler Migliorini 1999 - 2003 7.3L Power Stroke Diesel 8 03-04-2016 11:30 PM
6.4 Starter BobbyB 6.0L Power Stroke Diesel 10 12-26-2015 07:14 PM
front shock question Brian Wetherill Excursion - King of SUVs 1 10-11-2015 07:49 PM
Where to Buy: Locker and Gears for '03 F250 cold_beer839 1999 to 2016 Super Duty 13 01-25-2015 09:44 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
