Recommendations - Page 2 - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Recommendations
Old 08-10-2014, 11:18 AM
alloro alloro is offline
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
Quote:
Originally Posted by 03GRS View Post
Hi Alloro...I was told that if there was a bad vacuum, PCV valve, etc that the PCM would lean out the engine, causing the misfires.
Vacuum leak misfires are old school predating engine computers as we know them today. In today's world with a vacuum leak the computer can compensate to a point by enriching the mixture. OTOH misfires allow excess fuel into the exhaust, in turn the O2 sensors see less oxygen and figure the system is running rich, so the computer leans out the mixture, hence the P0174 code.
Old 08-18-2014, 04:34 PM
pdqford pdqford is offline
pdqford has a good reputation on FTE.pdqford has a good reputation on FTE.
Quote:
Actually, the misfire causes the oxygen to not be consumed, and therefore the O2 sensor sees too much oxygen and tries to compensate by adding more fuel.
You want to check the freeze frame data to see if the engine was under load when the code set. If it was , check the fuel filter and the fuel pump pressure. Inadequate fuel supply can cause a lean misfire and/or the lean code. Additionally the freeze frame will show the fuel trims so you can see if the PCM was trying to compensate, and if it was compensating on one or both banks.
If the engine was unloaded look for a vacuum leak.
Old 08-18-2014, 08:18 PM
Quote:
Might want to double check that bud.
Old 08-19-2014, 12:01 AM
alloro, I tried the PM thing but it said you are not accepting PMs.
See page 9 of this document. It explains better than I can what happens to O2 content of exhaust gasses when a misfire occurs.
http://www.autoshop101.com/forms/h56.pdf
Old 08-19-2014, 10:01 AM
r2millers's Avatar
r2millers r2millers is offline
r2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud of
Very good info. Thx for sharing.
Old 12-25-2014, 10:22 AM
krazeexp03 krazeexp03 is offline
krazeexp03 is starting off with a positive reputation.
Not too familiar with this thread but have worked on an 03 Expy and now have an 04. I have codes P0171 and P0174 currently on my 04. It had jumped to some other ones combined with the P0300 but got those to go away.
So, after reading numerous things online I am still trying to resolve the codes. I have replaced all 8 spark plugs with the OE motorcraft plugs, and I replaced the Heated PCV valve and line(infamous rear intake elbow) and still have the 171 and 174 codes.
Had it looked at by a mechanic who had checked for vacuum leaks...
Checked the MAF sensor and had cleaned it before the codes came on...
Any ideas what it could be? I am deployed so can't try any fixes right now but trying to think of things it could be so can tell my wife to tell the mechanic if it comes to that. Or, I will try when I return...Thanks for any input.
Old 12-25-2014, 11:21 AM
xSgtRenegadex xSgtRenegadex is offline
xSgtRenegadex is starting off with a positive reputation.
Check the fuel pump. That's what mine was.
Old 12-25-2014, 12:25 PM
Thanks for the input sarge...I thought about that being a possibility, but ugh...PIA to replace that...(did it on my 03 but ended up being a secondary fuel pump relay-another story)
I forgot to mention that I did replace the fuel filter and the air cleaner was also cleaned(not that that would cause a lean condition)
Haven't hooked up a fuel pressure tester but will keep the fuel pump idea in mind....and hey! I still have the one from the 03!! since it didn't end up being faulty...that will save $300...
What O-rings would be replaced? I saw that on some other comments somewhere...Thanks again!!
Old 12-31-2014, 10:46 AM
4srfox 4srfox is offline
4srfox is starting off with a positive reputation.
reply
Everything I purchase i check on:
google.com/shopping
put in any part number or model number and google has a search designed for
lowest prices. Works well.
'03 v10 y-pipe, good or bad??? nunomad Modular V10 (6.8l) 44 08-29-2016 10:56 AM
Trans cooler Migliorini 1999 - 2003 7.3L Power Stroke Diesel 8 03-04-2016 11:30 PM
6.4 Starter BobbyB 6.0L Power Stroke Diesel 10 12-26-2015 07:14 PM
front shock question Brian Wetherill Excursion - King of SUVs 1 10-11-2015 07:49 PM
Where to Buy: Locker and Gears for '03 F250 cold_beer839 1999 to 2016 Super Duty 13 01-25-2015 09:44 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
