no power help - Ford Truck Enthusiasts Forums
no power help
Old 08-02-2014, 05:44 AM
FordRun's Avatar
FordRun FordRun is offline
FordRun is starting off with a positive reputation.
no power help
was at bar tonight. stop had a couple then went to leave and had not even a click . had lights no turn over. I called a friend when he got their I had
like a dead battery . then he check the cables said pos was real hot
he thinks it was the starter. so he tow me home. we got truck home
even had a cop follow us. I know what you thinking. I live small town.
but anyway we had power steering fluid all over. maybe from tow ?
its a auto trans. he still thanks it starter. I have no lights . when I went start
it. it made 1 click I had lights. now no lights no clicks. any ideals ?
I hope its just starter. I thought even bad starter you still have lights.
Old 08-02-2014, 07:14 AM
ArdWrknTrk ArdWrknTrk is online now
pedant
ArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputation
You had power steering fluid all over because Ford C2 pumps will puke all over if you turn the wheel without the pump turning.
This is normal.
As for your dead battery, I'm going to suggest failed alternator.
There is no way for the starter to kill your battery while driving or you are sitting in the bar.
Disconnect the alternator cable from the fender solenoid and fully charge the battery.
Reinstall the battery.
Is there a big spark while attaching the battery cables?
If no,
Put a meter or test light between the battery+ solenoid stud and the detached alternator cable.
Does it light up brightly or the meter show significant amperage?
If so, you have a failed rectifier or the dreaded 2G "fire plug" has shorted to the case.
Old 08-02-2014, 11:01 AM
1995F150XLT4x4's Avatar
1995F150XLT4x4 1995F150XLT4x4 is offline
1995F150XLT4x4 is gaining momentum as a positive member of FTE.
Take the above advice ^
Old 08-02-2014, 10:17 PM
FordRun's Avatar
starter
it turn out it was the starter. I bought new one. running good. ty for help.
1973 F250 Long Bed Single Cab "Build" misscali91 1973 - 1979 F-100 & Larger F-Series Trucks 38 03-01-2016 05:44 AM
HELP! I need somebody...(starter problems, tried EVERYTHING) AtlM5 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 12 12-13-2015 08:57 PM
Help... Now battery isn't holding a charge. Resendiz Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 48 05-18-2015 01:00 PM
55' F100 Starter, Ignition, Solenoid....Hmmmm JoeSwing78 1948 - 1956 F1, F100 & Larger F-Series Trucks 34 08-23-2013 06:53 PM
Can't get er started... sasquatch999 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 10 06-10-2007 12:07 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
