Water pump removal difficulty
Trying to remove the water pump from a V10 6.8L triton on my RV. I have the water pump pulley off and removed the 4 bolts holding the water pump to the block but the pump will not come off? I assume it's just frozen on but I did not want to force it with out checking first. I did tap on it with a hammer and tried gently prying with a small crow bar but it acts like it's still bolted on. Any ideas?
I had my pump off, and it was a bit "sticky", but most likely there is some corrosion around the pump body. There is about roughly 3/8" between the face of the block/wp to the "O" ring that seals it. I would just tap a bit with a "tool" on the pulley flange top and sides, it will come loose. Just watch it doesn't fall and damage the radiator.
flapbreaker
08-01-2014 08:24 AM
g0dl355
13
11-08-2009 05:57 PM
