2000 Ford Mustang 3.8l
I just picked up a 2000 ford mustang for 200$. Friend was in need of cash and 200$ was all i had on me. About fail in the floor when he said solid lol!
Its got a clean title and everything.
He told me from the start the car needed a harmonic Balancer. He said that is what the repair shop told him.
I did not think this was the case but the Repair shop that told him this - Im good friends with. Anyway.
I got the BAlancer off - I dont see any issue with it. I dont see any cracks chips or brakes of any short.
Me myself - Im thinking this is a Tq/converter / flywheel issue - Im thinking the counter weights broke off and causing this! It dont seem to misfire - If you accl the engine it smooths out.
I also know cracked piston skirts and such can cause issues like this. Anyone got any ideas? Can some one throw some things at me that might cause this issue. Thanks - Video - https://www.youtube.com/watch?v=dZMN...ature=youtu.be
20140802_003906_zpsd6e0d434.jpg Photo by Bluemule93 | Photobucket
20140802_003915_zps0d3d1706.jpg Photo by Bluemule93 | Photobucket
Here are pics of the balancer - I dont see how these go bad? Any thoughts?
Well, they do. The rubber breaks down and they spin a little. Check out this one, worse than yours. Doesn't look worse than yours but it is:
2000 3.8l – Bad Harmonic Balancer? - Ford Mustang Forums
(picture in post 3)
Check post 20. Short version, balancer looked fine, no spin, no rubber. But a new balancer fixed the problem:
2000 mustang Major Vibration 3.8l - Mustang Boards
Earlier, I saw comments saying the balance shafts were front wheel drive motors only. Not so according to this. Your vibration my be the balance shaft, as with rpm it smooths out, which would be the result of all the slack in the timing chain being taken up. At idle, the chain goes slack and the cam and balance shaft goe out of synch. The balance shaft is geared to the cam, but the cam is chain driven.
http://www.enginebuildermag.com/2001...d-3-8l-engine/
But, the timing chain has a tensioner, which usually prevents the worn chain from getting sloppy enough to get the cam out of synch. It's possible the chain is beyond the limits of the tensioner or other troubles lurk behind that front cover.....
http://www.autozone.com/autozone/rep...00c15280250bfd
Try the harmonic balancer. If it still shakes, go deeper......
(picture in post 3)
Mikerage
1997 - 2003 F150
30
07-29-2016 02:59 PM
lilhelppls
07-09-2013 07:09 PM
Kiroshu
13
05-08-2010 12:41 AM
mustangsvo85
12-05-2006 08:32 PM
