Questions about replacing an e4od with c6. - Ford Truck Enthusiasts Forums
Old 08-01-2014, 11:49 PM
86pullerf350's Avatar
86pullerf350 86pullerf350 is offline
86pullerf350 is starting off with a positive reputation.
I just got a 94 f250 4x4 with 7.3 non turbo. The po had told me that he used it to plow his dirt driveway in the winter and grade it in the spring with the plow. He beat the trans pretty good but the engine still runs excellent. I need to do some other things such as glow plugs and filters.
I have a C6 from an 1986 f250 4x4 with about 2000 miles on it that i would like to put in place of the e4od. The c6 came out of a parts truck I have so I have the wiring harness for it. I found on here somewhere that someone has done it but cant find it again. I know the crossmember needs to be moved forward, c6 needs a vacuum line to it, and obviously the harness needs to be changed.
What else do I have to look for? How would I rewire the two harnesses together to make it work?
Any suggestions will help.
Thanks
Need wiring harness for 1993 f250 5.8 JClark785 1987 - 1996 F150 & Larger F-Series Trucks 2 11-13-2016 08:52 PM
Will trans from 88 4x4 Diesel engine go into 91 4x4 Gas Wolfy77 1987 - 1996 F150 & Larger F-Series Trucks 3 09-29-2016 11:43 AM
Looking at first 7.3 IDI f100beatertruck Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 9 10-27-2014 02:57 PM
Looking for 92-97 460 4x4 terryknight WTB - Ford Trucks & other vehicles 0 08-17-2014 10:05 PM
A couple questions about replacing an E4OD with a C6 86pullerf350 1987 - 1996 F150 & Larger F-Series Trucks 2 08-05-2014 01:02 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
