Truck not running right - Ford Truck Enthusiasts Forums
Old 08-01-2014, 11:01 PM
imjwm's Avatar
imjwm imjwm is offline
imjwm is starting off with a positive reputation.
I am really trying to figure out what is wrong with my 95 Ford f250 7.3 diesel.
Drove the truck to work but when I left this evening soon after I started it it started to sputter and not run right so I shut out off and restarted it and it ran fine for a little bit but then started to do it more and more, now it does it right when I start it. It sounds like it is only running on a few cylinders! I first thought it might be out of fuel so I put more it still does it. any help will be much appreciated! Thanks
Old 08-01-2014, 11:13 PM
madMatador78's Avatar
madMatador78 madMatador78 is online now
madMatador78 is gaining momentum as a positive member of FTE.
Sounds like it could be the valve cover harnesses. There are 2 per side. Check them carefully! They like to melt.
Old 08-02-2014, 12:56 AM
Bob Cat Bob Cat is offline
Bob Cat is starting off with a positive reputation.
Maybe the CPS sensor?
Old 08-03-2014, 11:55 AM
imjwm's Avatar
I think it is the connector that goes to the valve cover gasket, it is really melted!
Old 08-03-2014, 11:34 PM
oldbird1965's Avatar
oldbird1965 oldbird1965 is online now
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
You found your problem!
Old 08-04-2014, 09:45 AM
^^^ X2, that be your issue. Not a bad job to do.
Old 08-06-2014, 10:11 AM
imjwm's Avatar
I thought I found the problem but I fixed that and it still does it! I pulled the valve cover and tested for power and it works fine but it still doesn't run right! What could it be now?
Starting issues nut_wrinkle Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 19 06-29-2016 01:22 AM
Can heat soak be intermittent? Maybe it's something else? EYEDEYE Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 23 09-26-2015 02:42 PM
Hesitation, Skipping at Low RPM's (long) Swanolck 1999 - 2003 7.3L Power Stroke Diesel 44 06-03-2015 10:10 AM
Injector pump ?, think I need one. Realslowww Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 19 03-26-2015 09:45 PM
Truck stalled when I turned wheel at startup, wont start now. marcomjl 1999 - 2003 7.3L Power Stroke Diesel 28 02-28-2012 08:56 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
