Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1973 - 1979 F-100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Welcome to Ford-Trucks Forums!
Welcome to Ford-Trucks.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Ford-Trucks Forums community today!
Old 08-01-2014, 08:17 PM
Negrey Negrey is offline
Negrey is starting off with a positive reputation.
Rad Hoses for Super Cooling Rad
Hey Guys,
So I'm putting the rad from my body donor truck (1978 F150 2wd 460 Auto) into my project truck (1978 F250 4x4 400 manual) I believe its a "super cooling" rad because it measures around 4.5" thick, 27" wide and 30" tall, and looks massive in the engine bay! The original measures around 1.5" thinner and 5" shorter in height. Now my problem, I ordered rad hoses for my truck as per stock, needless to say they didn't fit. The upper rad hose was a bit too long, I could make it work. The lower rad hose was completely wrong, cause the rad is taller! Does anyone know if formed hoses that will work for me exist? My parts guy wasn't having a lot of luck. Or do I need to go with the universal flexible hoses? I'm hoping I'm not the first to have this issue! Thanks!!
__________________
1978 F250 4x4 400 Manual
Old 08-01-2014, 08:21 PM
co425's Avatar
co425 co425 is offline
co425 has a great reputation on FTE.co425 has a great reputation on FTE.co425 has a great reputation on FTE.co425 has a great reputation on FTE.co425 has a great reputation on FTE.
I used the stock 1974 F250 4x4 360 hoses with my old 460 and super cool radiator swap. They worked fine.
__________________
1974 F250 4X4
Cummins 12v, NV4500 , np205, Dana 60 Front, GM 14 bolt rear.
Cummins swap/truck upgrade thread
http://m.ford-trucks.com/forums/show....php?t=1181279
LIBERALISM IS PESTILENCE!!!
Old 08-01-2014, 09:29 PM
grinnergetter's Avatar
grinnergetter grinnergetter is offline
grinnergetter is gaining momentum as a positive member of FTE.grinnergetter is gaining momentum as a positive member of FTE.
My 73/460/SC radiator uses a flex on top and a stock lower, cut it just below the ps belt and has a piece of muffler tube to drop it low enough to get to radiator. Not the prettiest but works well enough.
Maybe one from a Super Camper Special might be the ticket????
__________________
1973 F250 "the Evil One"
1979 F250
1972 Crew Cab.
Old 08-02-2014, 02:22 PM
orangeford's Avatar
orangeford orangeford is offline
orangeford is starting off with a positive reputation.
When I did this same radiator swap with a 351m I used a gates/ecr part # 21090. See if you can find an equivalent. The super cooler radiator bottom extends goes down further than other radiators and requires a special hose.
__________________
79 F150 XLT 4x4, 460 auto.
http://www.supermotors.net/11333
Old 08-02-2014, 04:23 PM
77blue 77blue is offline
77blue is starting off with a positive reputation.
I have a351M in my 1977 f150 2wd. I got my hoses (super cooling) from NAPA. Upper #7757, lower #7799. Hope this helps.
Old 08-02-2014, 08:45 PM
alchemist1 alchemist1 is offline
alchemist1 is starting off with a positive reputation.
Formed hoses can work. You have to go off of the radiator rather than the engine on your application. But also keep in mind that particular engine may not have had that particular radiator. In my case I have a weird combination - a non heavy duty radiator in my 74F100 and a 390 FE engine. Sounds normal, but the 390 is from a 67 Fairlane, and that engine's thermostat elbow and water pump (lower hose) outlet are way different than a 74 F100 390. Also, outlet/inlet diameters were different. Gates makes reducers and I had to use one on my radiator.
__________________
95 DGGM Impala SS, 396, LT4 cnc heads, LT4 matched intake, Holley 58 mm t/body, GM 847 cam, GMPP 1.5 rr's, F-body MAF, tuned OBD I PCM, LT4 knock module, K&N cold air, Edelbrock headers, Flowmaster exhaust, BBHP #73 6-speed, 4:56 gear, sloted and drilled rotors, Z28 cluster
77 F150 Ranger 400 auto longbed - no longer running
74 F100 67 390 Fairlane GT motor, 2WD, LB
Old 08-03-2014, 12:09 AM
Thanks guys! The issue with the lower rad hose is the big crossmember that runs in front of the engine, it'd almost need two bends in the hose to clear it. I did think of making a steel one and then use hose to attach it to the pump and rad. Thanks for the part numbers, I'll look into those!
__________________
Old 08-03-2014, 12:56 AM
co425's Avatar
Quote:
The lower 360 hose cleared the crossmember in my truck.
__________________
1974 F250 4X4
Old 08-03-2014, 02:13 AM
mofoco1 mofoco1 is offline
mofoco1 is starting off with a positive reputation.
My 79 SC F-250 has what I believe is the Supercooler rad as it too is very thick same dimensions as given before. I did not change the bottom, but di replace the top with a Gates from AutoZone. For 79 460. It was too long by 1.5" so I cut it and installed with the good SS T-bolt clamps. Worked fine, although the forming is not as good as they were years ago. At some point when I have more time I will have SS tubing bent to shape and use short silicon hose instead. I like the bullet proof aspect of a set up like that. I am also going to have an aluminum shroud made that is deeper and have it so it splits in half to make removal of the fan and accessories easier.
Old 08-08-2014, 12:03 AM
Tried 360 rad hoses today, Diameter was too large and bends were wrong. I'm going to go back to the original ones and stretch the lower with a piece of pipe and clamps. I'd like to avoid the universal route if possible, just think formed look cleaner.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Similar Threads
95 PSD rad in an 89 IDI?????? Pheadrus Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 6 03-27-2014 07:29 AM
94 f250 gas rad & 94 f250 diesel rad enosez 1987 - 1996 F150 & Larger F-Series Trucks 0 04-02-2013 03:46 PM
Help on lower rad hose on a SD 5.4L upstream Modular V8 (4.6L, 5.4L) 4 10-19-2007 02:43 AM
'67 F100 352 to 390 cooling issue Comegetsome 1967 - 1972 F-100 & Larger F-Series Trucks 9 08-15-2003 05:17 PM
351m radiator options weldman 1973 - 1979 F-100 & Larger F-Series Trucks 15 08-18-2001 10:46 AM
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
vbulletin Admin Backup
