early 99 powerstroke p1670 code. what to do now?
08-01-2014, 05:09 PM
on
truck wont start no mater how hard i push the clutch in. i pulled the code p1670 with a superchip had held programmer. i read that it could either be the IDM or the CPS where should i start? i need this truck back up and running asap.
it aslo threw a cam sensor code with it. please help guys
08-01-2014, 05:24 PM
on
Communication error between PCM and IDM. Check your fuses. I think the IDM relay is one of the relays on the fuse panel. If so try swapping the IDM relay with the accessory relay.
08-01-2014, 05:45 PM
on
So they are the same type of relay? I just take the accessory one and use it for the IDM?
08-01-2014, 06:06 PM
on
Yes. All the relays on the fuse panel the same.
08-01-2014, 08:50 PM
on
What does the accessory relay control? Could I steal that and use it so I can drive the truck till I get one if that's the problem?
08-01-2014, 09:02 PM
on
The accessory relay controls the power windows and radio and things like that. Yea, you can drive the truck with out it.
08-01-2014, 09:06 PM
on
Ok can I get the relay at like a napa?
08-01-2014, 09:17 PM
on
I'm pretty sure you have to get the relays from the dealership. They're about $13 I think?
08-01-2014, 10:08 PM
on
Ok sounds good. Thanks for the help guys
08-02-2014, 11:26 AM
on
Now what guys? Tried changing the relay out with another one and still nothing!. I'm completely stumped right now.
08-02-2014, 11:28 AM
on
I can bump start it and it will run just fine.
08-02-2014, 11:44 AM
on
Quote:
Originally Posted by
fordguy2236
Please explain.
Atleast that rules out any IDM issues.
08-02-2014, 12:11 PM
on
My drive way is a hill if I role down it and drop the clutch in second it will start. Would that be the clutch sensor?
08-02-2014, 12:14 PM
Can you clarify the problem a little better? Is it that it won't crank at all with the key, or will it crank but not start and run?
08-02-2014, 12:27 PM
on
You can try swapping the starter relay
