trailer brakes
Old 08-01-2014, 03:18 PM
panelguy's Avatar
panelguy
panelguy is offline
trailer brakes
Hello, I have a 2001 f150 xtr , it has the towing package with two trailer plug ins . I 'm wondering if the trailer brakes are powered when you apply the truck brakes as I don't see ant indicators of this happening such as a light.
Would the trailer brakes be wired from the factory ?
Thanks
Old 08-01-2014, 10:10 PM
steve(ill)'s Avatar
steve(ill)
steve(ill) is offline
No, you need to get a brake control unit. Companies like Prodogy make a good unit. It is a small box that mounts under the steering column to the bottom of dash. It will have a 6 prong plug that will connect to an empty harness plug under your dash. THe unit has a pendulum and monitors the deceleration of the truck and send a proportional voltage signal to the brakes. I will post a link to the Prodogy unit that I bought on e-bay.. Don't go cheap, then don't work as good as the "proportional" units.
Old 08-01-2014, 10:15 PM
steve(ill)'s Avatar
steve(ill)
attached link also shows photo of the electrical plug. NOTE.. P2 units are all the same, but you need a specific adaptor harness for different trucks.
http://www.ebay.com/itm/Prodigy-P2-Electric-Trailer-Brake-Controller-90885-w-Ford-Harness-3035P-Pre-2010-/370743994084?pt=Motors_RV_Trailer_Camper_Parts_Accessories&hash=item56521066e4&vxp=mtr
Old 08-01-2014, 11:12 PM
Bluegrass 7's Avatar
Bluegrass 7
Bluegrass 7 is offline
You need to mount and connect an after market controller in the cab.
There is a provided connector under the dash. You need the adapter cable from the controller to the Ford connector.
You need to install a relay and fuse in the engine bay fuse box to complete the job.
Then calibrate according to brake controller instructions with trailer attached.
Trailers over 3000 lbs usually require aux brakes, a safety break-away cable actuated switch, and a trailer mounted battery to operate the brakes should the trailer get free form the tow vehicle.
Surprise!
Good luck.
Old 08-02-2014, 06:18 PM
panelguy's Avatar
panelguy
panelguy is offline
Thanks for your answers this site is great for replies, I picked up a controller and installed it today very easy and I check and have power to the rear connector.
jaygee15
2015 - 2020 F150
12-28-2017 03:12 PM
gtex
1997 - 2003 F150
01-02-2007 07:44 PM
Slewfoot
1999 to 2016 Super Duty
02-13-2003 06:25 AM
dcmsu
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
18
08-21-2002 11:39 PM
pasobuff
11-21-2001 03:37 PM
Quick Reply: trailer brakes
