New
New
This is my first post as the new owner of a 1951 F1 with a '71 Torino 351 engine, transmission and 9" rear end. The rear is lowered with removed leaves, and front is (will be) lowered with a dropped axle. I aim to keep as much of the original steering and suspension as practical so I am rebuilding the steering box, king pins etc. A recent survey of the frame indicated I will need to add some frame boxing, motor mount corrections, and fish plates to address some rigidity, cracking and capacity issues. A power brake booster is planned after the rear motor mount is remodeled to make it removable (welded in now). Since the transmission will be removed, I figured this will be as good a time as any to try rebuilding an automatic transmission which I have thought about for years...I'm 68 so I guess it is never too late to learn and I have lots of time now. I'll discuss further plans in a later post.
Welcome! Watch out when lowering the front, you can end up with some drag link geometry problems:
https://www.ford-trucks.com/forums/1...ump-steer.html
https://www.ford-trucks.com/forums/1...s-springs.html
ocation
I'm in Vancouver USA. Yup, it's a C4. PO did present it as somewhat better than reality. Not totally unexpected I guess. I personally couldn't let something go with all the issues I have found so far without a heads up. I would not want anyone to think that was my level of expectation or skill.
Discoveries
Exploration on the new 'baby' has revealed all sort of interesting findings. Probably most nerve wracking so far was the thin zip ties holding things in place at the e-brake pivot assy. After the 9" install, modifications were not made to connect the late model e-brake cables to the O.E. pivot. (Sigh). Improperly clamped fuel lines from an electric pump could have proven insufficient.
Exploration is a good thing. You don't want surprises if you're out on the road. Even if you do have a problem, at least you will be familiar enough with the truck to know what you're looking at.
We would love to see some pictures. Of the truck that is.
Before I had grey hair some friends and I used to come to your corner of the country and do some hiking around the big mountains. Once we spent July 4th at a campground called Deer Park and watched the fireworks at Port Angeles and Victoria. It was interesting to see the fireworks below us.
Future plans
After examinations so far, it looks like I'll be be pulling off the box, cab and front clip to better access the repairs I feel are needed. At that point the frame will probably get wire brushed and painted with Por 15 or something of that nature. It looks like I need to start with a proper radiator and proceed rearward. Details to follow......
I'm pretty sure my panel has the same setup you have but from a Mustang. My 9" is a 2.75.
I had the same problem with the eBrake. Bought a rear cable from MidFifties and that solved the problem. Be sure to get the one with the yoke. Should hook right up to your front cable no problem.
