New - Ford Truck Enthusiasts Forums
New
Old 08-01-2014, 03:03 PM
Fordycouv's Avatar
Fordycouv Fordycouv is offline
Fordycouv is starting off with a positive reputation.
New
This is my first post as the new owner of a 1951 F1 with a '71 Torino 351 engine, transmission and 9" rear end. The rear is lowered with removed leaves, and front is (will be) lowered with a dropped axle. I aim to keep as much of the original steering and suspension as practical so I am rebuilding the steering box, king pins etc. A recent survey of the frame indicated I will need to add some frame boxing, motor mount corrections, and fish plates to address some rigidity, cracking and capacity issues. A power brake booster is planned after the rear motor mount is remodeled to make it removable (welded in now). Since the transmission will be removed, I figured this will be as good a time as any to try rebuilding an automatic transmission which I have thought about for years...I'm 68 so I guess it is never too late to learn and I have lots of time now. I'll discuss further plans in a later post.
Old 08-01-2014, 03:09 PM
FortyNiner's Avatar
FortyNiner FortyNiner is offline
FortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to behold
Welcome! Sounds like you know your challenges from the previous owner (PO). We certainly want to get you back on the road soon. Thanks for checking in. Where in the world are you?
DW
Old 08-01-2014, 03:18 PM
arctic y block's Avatar
arctic y block arctic y block is offline
arctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputation
Ya most likely have a C4 in it. Prolly one of the easiest auto trannys to overhaul. Get a master kit and follow the instructions. Good luck and we are here to help.
Old 08-01-2014, 04:28 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
Welcome! Watch out when lowering the front, you can end up with some drag link geometry problems:
http://www.ford-trucks.com/forums/13...ump-steer.html
http://www.ford-trucks.com/forums/12...s-springs.html
Old 08-01-2014, 05:21 PM
Fordycouv's Avatar
ocation
I'm in Vancouver USA. Yup, it's a C4. PO did present it as somewhat better than reality. Not totally unexpected I guess. I personally couldn't let something go with all the issues I have found so far without a heads up. I would not want anyone to think that was my level of expectation or skill.
Old 08-01-2014, 07:57 PM
Wayne Waldrep's Avatar
Wayne Waldrep Wayne Waldrep is offline
Wayne Waldrep has a very good reputation on FTE.Wayne Waldrep has a very good reputation on FTE.Wayne Waldrep has a very good reputation on FTE.Wayne Waldrep has a very good reputation on FTE.
Welcome to the forum! Glad you found us and look forward to seeing more info and pics of your truck.
Old 08-01-2014, 08:51 PM
EffieTrucker's Avatar
EffieTrucker EffieTrucker is offline
Kentucky Chapter Member
EffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to behold
Welcome from Eastern Kentucky!
Congrats on the new "baby". I hope you enjoy working on it and driving it a lot.
Old 08-01-2014, 08:59 PM
underthebridgejim's Avatar
underthebridgejim underthebridgejim is offline
FTE fan
underthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputation
Welcome, welcome, welcome, it's always nice to have another F1 amongst us, along with there handler LOL. Looking forward to your progress, we love to watch (pics) and help if needed.
Old 08-02-2014, 08:00 AM
Fordycouv's Avatar
Discoveries
Exploration on the new 'baby' has revealed all sort of interesting findings. Probably most nerve wracking so far was the thin zip ties holding things in place at the e-brake pivot assy. After the 9" install, modifications were not made to connect the late model e-brake cables to the O.E. pivot. (Sigh). Improperly clamped fuel lines from an electric pump could have proven insufficient.
Old 08-02-2014, 09:24 AM
Exploration is a good thing. You don't want surprises if you're out on the road. Even if you do have a problem, at least you will be familiar enough with the truck to know what you're looking at.
We would love to see some pictures. Of the truck that is.
Before I had grey hair some friends and I used to come to your corner of the country and do some hiking around the big mountains. Once we spent July 4th at a campground called Deer Park and watched the fireworks at Port Angeles and Victoria. It was interesting to see the fireworks below us.
Old 08-02-2014, 09:45 AM
Fordycouv's Avatar
Future plans
After examinations so far, it looks like I'll be be pulling off the box, cab and front clip to better access the repairs I feel are needed. At that point the frame will probably get wire brushed and painted with Por 15 or something of that nature. It looks like I need to start with a proper radiator and proceed rearward. Details to follow......
Old 08-02-2014, 09:31 PM
bjmayberry2's Avatar
bjmayberry2 bjmayberry2 is online now
bjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud of
Quote:
Welcome!
I'm pretty sure my panel has the same setup you have but from a Mustang. My 9" is a 2.75.
I had the same problem with the eBrake. Bought a rear cable from MidFifties and that solved the problem. Be sure to get the one with the yoke. Should hook right up to your front cable no problem.
Old 08-02-2014, 10:21 PM
Quote:
Originally Posted by bjmayberry2 View Post
Welcome!
Back in the day they would call those "airplane gears".
Old 08-03-2014, 01:12 AM
52 Merc's Avatar
52 Merc 52 Merc is offline
52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of
This is my first post as the new owner of a 1951 F1...
Welcome to the forum, neighbor! It sounds like you've got quite the project on your hands. Post up some pics when you get a chance.
Old 08-03-2014, 02:06 AM
Olweldinrig's Avatar
Olweldinrig Olweldinrig is offline
Olweldinrig is gaining momentum as a positive member of FTE.Olweldinrig is gaining momentum as a positive member of FTE.
Welcome!Sounds like a fun truck!A friend had a 71 torino with a cleveland and boy it hauled!!
1955 F100 Re-assembly thread johnson.jeff.a 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 10-06-2015 12:24 AM
Installed ARP Studs Without Pulling Motor, Lifting Cab or Removing HVAC Box DSMMH 6.0L Power Stroke Diesel 118 08-17-2015 01:35 AM
Oil Leak @ Oil Cooler Adaptor Fixed! HearseDriver Modular V10 (6.8l) 2 05-28-2015 12:42 AM
Automatic E40D Swap to 5 Speed (Mazda M5R2) Ztitan 1987 - 1996 F150 & Larger F-Series Trucks 52 01-25-2015 10:55 AM
progress on my 56 frame.....Lexus IFS lexcoe 1948 - 1956 F1, F100 & Larger F-Series Trucks 179 08-22-2014 11:44 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
