Dually conversion? - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Dually conversion?
Old 08-01-2014, 01:00 PM
bill wilson's Avatar
bill wilson bill wilson is offline
bill wilson is starting off with a positive reputation.
Dually conversion?
Hey guys I've had my 97 1 ton for a while and I'm thinking about making her a duall. She's 4WD and I was wondering if any of you have any good places to shop for conversion stuff? Websites anything. Thanks guys.
Old 08-01-2014, 07:56 PM
farmert farmert is offline
farmert has a good reputation on FTE.farmert has a good reputation on FTE.farmert has a good reputation on FTE.
If you have any salvage yards/ auto wreckers in your area, go there and look for an 86-97 F350 dually truck that left the factory with a pickup bed installed. The rear axle will be a direct bolt in on your truck. Those axles are 4 inches wider from brake backing plate to backing plate, so the tires will clear the springs. Make sure the gear ratio is the same as your front. The same yard may have the front dually hubs for the Dana 60 so you can run the same dually rims on the front. This is the way I'd convert a single rear wheel truck to duals. Arrowcraft makes a conversion kit, but they use spacers, not ideal in my opinion. They also sell the rear dually fenders for your box.
Old 08-02-2014, 08:54 PM
Alright thanks a lot. I figured the axle swap would be the best and quickest.
Single to Dually Conversion Austinnbole 1999 to 2016 Super Duty 52 12-30-2015 11:04 PM
True Ford Disc brake conversion? tazcliff 1948 - 1956 F1, F100 & Larger F-Series Trucks 48 11-03-2015 02:42 PM
dual wheel conversion fourboltmain3401 Projects 1 02-03-2015 11:34 AM
DUAL WHEEL CONVERSION fourboltmain3401 1973 - 1979 F-100 & Larger F-Series Trucks 0 01-28-2015 08:41 PM
E40D to manual conversion IDI guy Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 01-02-2012 09:29 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
