View Poll Results: Which 2015 F150 engine would you pick?
Naturally aspirated 3.5L V6
2.02%
5.0L V8
135
45.45%
2.7L EcoBoost V6
43
14.48%
3.5L EcoBoost V6
113
38.05%
Voters: 297. You may not vote on this poll
Question of the Week: Which 2015 Ford F150 Engine Would You Pick?
#46
I voted for the 2.7 for better fuel economy. In the past little engines have always been a mistake but this one with dual turbos and tons of hp as well as fuel economy is like having your cake but eating it too.
#48
Maybe you could put a lolly stick in the back wheel like we did as a kid to make more noise on our bicycles....lol
#49
The 5.0L. It's the easiest to work on and will be the most cost effective to repair in the future. Also, add-on aftermarket mods are numerous if needed. I would say it's the most dependable because of it's traditional design and reliability.
#50
Terry
#52
There are serveral things that may effect wear in an engine:
1) hours running
2) total revolutions
3) how "hard" it works.
1) In an apples-to-apples comparison, the ecoboost will run the same number of hours as any V8, so that's a wash.
2) In my truck, the ecoboost runs at much lower RPM's than my old 5.4L V8, so it should come out well ahead here.
3) this is a bit of an intangible. I know of no numerical way to measure this.
My guess is that you won't be able to estimate reliability by any of the old rules of thumb. I have seen no hard data to say that the new 5.0L is any more reliable than the EcoBoost.
#53
I know this "feels" true, but let's inspect this idea for a minute.
1) hours running
1) hours running
5.0L gives you V8 tone, solid power, low maintenance, and good fuel economy. That'd be my choice.
#54
I think the 'how hard it works' is important. Higher compression engines are placing more 'stress' on heads, blocks, valves, cams, etc., etc. I'm guessing off-boost the 3.5TT is lower compression than the 10.5:1 V8. On boost, however, it probably works harder. Higher compression engines may lose compression quicker, or are more likely to have oil consumption problems later on in life. Lets not forget the the TT V6 engines are direct-injected, meaning no fuel is cleaning the back of the intake valves...At some mileage point carbon will probably build up to the point where the valve doesn't close properly...and will need to have work done to de-carbon the intake / valves. This has been a problem in DI-VW engines for years now. Also, turbos require good lubrication and cooling...this is an area where the TT may not be as forgiving on oil change interval as the 5.0L.
#55
Not trying to start a debate, but there's a lot more to this than I think you are trying to understand. A boosted engine designed to be put into a pickup truck is built a lot different from a naturally aspirated engine. You are aware that just about every single semi truck on the road is powered by a six cylinder engine, right? Yeah I know, apples and oranges, but those turbocharged six-bangers are known to last a million miles moving up to, and sometimes over, eighty thousand pounds. There is a LOT more to longevity than cylinder count.
#56
The ECO Boost pulls 11000 lbs?
The ECOBoost can pull a travel trailer of 8000lbs?
I posted a question about my intent to pull 8000lb travel trailer and a 700lb golf cart in my future 2014-2015(have not made my mind yet)
#57
The EB and the 5.0L share a 10.1 compression ratio. They have nearly an identical bore and stroke. The EB has 4 main bearing supporting six cylinders while the 5.0L has five mains supporting eight cylinders.
The biggy here for me is that the EB makes it's peak TQ of 420 ft/lb at 2500 RPM's while the 5.0L must rev up to 4500 to achieve it's peak tq.
The EB is a truck engine that has been detuned for use in sedans and crossovers.
#58
A turbo for the EcoBoost engine is less than $600, and they don't take much time to replace. And you really think adding a supercharger for an engine never designed for forced induction isn't going to hurt longevity?
#60
If the 2.7 does what they say it does, it'll be great. But, with all the changes to the truck as a whole, plus the all new engine (2.7L) with all the different technology, I think they're going to have some growing pains. No doubt they will get them worked out, but no thanks......
