VA August End of Summer BS Thread. - Page 58 - Ford Truck Enthusiasts Forums
Virginia Chapter Join Chapter, Leader:
  #856
Old 08-23-2014, 09:05 PM
Sparky83's Avatar
Sparky83 Sparky83 is online now
Posting Legend
Sparky83 has a superb reputationSparky83 has a superb reputationSparky83 has a superb reputationSparky83 has a superb reputationSparky83 has a superb reputationSparky83 has a superb reputationSparky83 has a superb reputationSparky83 has a superb reputationSparky83 has a superb reputationSparky83 has a superb reputationSparky83 has a superb reputation
was but i put the O-ring on from the plug and it stopped that... the adapters was too small and let it leak.. put the other o-ring on it stopped it...
apparently thats supposed to be a normal reading...and was getting it for a bit... but after i stopped at a store i started getting this as a constant reading...
stayed there the whole way home... not sure if the sensors bad, the wire harness shorted... dont think its the gauge... unsure of the fuel pump...
  #857
Old 08-23-2014, 09:51 PM
archtaan's Avatar
archtaan archtaan is offline
archtaan has a superb reputationarchtaan has a superb reputationarchtaan has a superb reputationarchtaan has a superb reputationarchtaan has a superb reputationarchtaan has a superb reputationarchtaan has a superb reputationarchtaan has a superb reputationarchtaan has a superb reputationarchtaan has a superb reputationarchtaan has a superb reputation
Fuel pressure usually moves, especially under wot. Might be the fitting.
  #858
Old 08-23-2014, 09:58 PM
Sparky83's Avatar
Posting Legend
but shouldnt be dropping below 45psi...
  #859
Old 08-23-2014, 10:15 PM
archtaan's Avatar
Do you have the blue spring upgrade?
,and yes. 45psi is the minimum. I wonder if its an install/fitting issue. Maybe one of those o-rings gave out?
  #860
Old 08-23-2014, 10:18 PM
fire240's Avatar
fire240 fire240 is online now
fire240 has a superb reputationfire240 has a superb reputationfire240 has a superb reputationfire240 has a superb reputationfire240 has a superb reputationfire240 has a superb reputationfire240 has a superb reputationfire240 has a superb reputationfire240 has a superb reputationfire240 has a superb reputationfire240 has a superb reputation
Have a good one guys. Almost time for me to head out for the night.
  #861
Old 08-23-2014, 10:26 PM
Sparky83's Avatar
Posting Legend
yup got the blue spring... was one of the first mods i did...
only one O-ring for the fitting... and had to use the adapter... threads werent the same.. Sensors threads are fine... where the plugs coarse threads..
Did have to use the original oring from the plug... the one that came on the adapter was too small... as soon as the pressure built it leaked..
  #862
Old 08-23-2014, 11:56 PM
archtaan's Avatar
Looks like you will need to call and see if they can send you the correct fitting. I think its not ready right because its probably bleeding pressure.
  #863
Old 08-23-2014, 11:59 PM
Sparky83's Avatar
Posting Legend
im wondering if i broke the wire pulling it through the fire wall
  #864
Old 08-24-2014, 12:17 AM
archtaan's Avatar
If you have a voltage tester you can check it before and after to see if there is voltage drop. Its possible its ground shorting though.
You could run a new wire outside the cab into the gauge just to check it. That way you dont have to deal with fishing it through the firewall.
  #865
Old 08-24-2014, 12:20 AM
Sparky83's Avatar
Posting Legend
when the ground itself is bad the needle pegs to 100... had that already.. ground wire backed out when i plugged into the gauge..
  #866
Old 08-24-2014, 12:21 AM
Sparky83's Avatar
Posting Legend
was reading online earlier.. that apparently alot of people have gotten bad sensors from them..
  #867
Old 08-24-2014, 12:35 AM
archtaan's Avatar
Do a quick wire test then call them. They will take care of it. I'm off to bed. Later.
  #868
Old 08-24-2014, 12:41 AM
Sparky83's Avatar
Posting Legend
i emailed them asking for how to test the sensor..
  #869
Old 08-24-2014, 10:55 AM
archtaan's Avatar
Probably measure the ohms
  #870
Old 08-24-2014, 11:10 AM
GLR's Avatar
GLR GLR is offline
GLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputation
Good "Go Topless Day" to all.
**** bradphx 1973 - 1979 F-100 & Larger F-Series Trucks 59 12-05-2016 03:27 PM
ooops Aerostar 5 01-14-2015 03:16 AM
... miko6810 Modular V10 (6.8l) 9 06-04-2014 06:14 AM
Albums 56panelford 1948 - 1956 F1, F100 & Larger F-Series Trucks 18 05-29-2014 11:16 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
cat farts, corn, fighting fires, hot, modding, new camera, new garage, new york, no time to slack, pizza, snow anyone, thanks shawn, tim is naked, tornadoes, vacay
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
