No crank , no start Banks IQ W/six gun
Old 08-01-2014, 03:54 AM
Mustangoutcast's Avatar
Mustangoutcast
Mustangoutcast is offline
I pulled out of the store and pulled out into traffic heading for work as I always do. But this time It Died Period. My Banks IQ shows a tuner code 3,4 and says CAN communications ERROR with vehicle OBD system. Banks book says check 46 pin connectors and connection, as well as OBD port connection. and check again. Same Dead *** truck as before. with no more instructions. I have a dash light above the glow plug light is out, the check gauge light lit, check engine light lit. I can not get any codes because the OBD is not communicating. At a bit of a loss here guys. could really use help. I removed tuner completely with no change. no codes on scangauge.
Old 08-01-2014, 08:13 AM
mustang_309's Avatar
mustang_309
mustang_309 is offline
Can you get the engine to turn over using the method in this video? If you can then have you tried starting in neutral? if that doesnt work start unplugging 3 wire connectors in the engine compartment one at a time and see if you can get it to turn over with the key, start with the clutch fan connector first.
Old 08-01-2014, 08:19 AM
WatsonR's Avatar
WatsonR
WatsonR is offline
have you checked the fuse for the OBD port?
Old 08-02-2014, 11:38 AM
Mustangoutcast
I cannot find an OBD fuse, I found a data link fuse(good) . My check engine light is on. I cannot get any codes from truck with either the scanner or the scangauge2.\
Old 08-02-2014, 01:56 PM
Mustangoutcast
Is there a way to Verify the PCM is bad besides replacing it with a known good one? I would hate to put out $300+ for nothing.
Old 08-02-2014, 02:35 PM
npccpartsman's Avatar
npccpartsman
npccpartsman is offline
The OBDII port is powered on the same fuse listed as cigar lighter. I's not the same fuse as the power port. If both those are powered then the OBDII port should read.
Old 08-03-2014, 09:50 PM
Mustangoutcast
Yeah that one says cigar lighter, datalink in my book. And yes it is a good fuse. took it out did visual, put it on ohm meter, and checked voltage on both sides of fuse once it was plugged back in. still no obd communications. I ordered the schematics for this truck but it will be a few days before I get it. I've bombed a couple other sites as well as ASK and so far the majority leans towards the PCU. Anyway to verify outside of the dealership?
Oh yeah, I removed all connections with my Banks six gun, returned to factory stock. still no read with scangaugeII.
Thanks guys, I usually get what I need without asking, just search and I usually find. I appreciate the help.
Old 08-04-2014, 07:59 AM
Mustangoutcast
Blown fuse #22
I got fed up and decided to go thru and check voltage on both sides of ALL my fuses with key on and found that the fuse that Banks has me tap off from is blown. I removed the tap and tried a new fuse and it blew as soon as the key went hot. the manual I have says "engine control" I haven't got my manual yet so any help guys?
Old 08-06-2014, 01:28 AM
Mustangoutcast
got the manual
Put an Ohm meter on the fuse lead to ground got 3.5 ohms, went thru circuits and connections until the short disappeared. turned out to be the front connector on the glow plug module. But when I went to prove out the short and reconnect the circuit it would not short out again. So new fuse, hooked everything back up and still no OBD II port communication. So I am fairly certain that I burned something up. whether a fusable link or a module some where. This manual is pretty detailed so I will plug away with the pinpoint checks and such until I have a culprit. I will keep posting incase this could help someone else.
Anyone got Ideas I would gladly entertain them.
Thanks
Old 08-22-2014, 04:21 AM
Mustangoutcast
New PCM
Put in a new PCM, Still no communication with Scangauge II. Went to do the point to point and my truck doesn't have the bulkhead connector that the print says should be there. So I am gonna work as much overtime as I can , Call a wrecker and the ford dealership. Call my credit union and lineup financing. I feel at least a grand lighter, and It hasn't even left the yard yet.
I haven't got much of a response on here so I don't know if anyone is even interested in what it might be. But when I get the news from the dealer I will Post.
Old 08-22-2014, 07:28 PM
cheezit's Avatar
cheezit
cheezit is offline
First issue is banks six gun. Imo. This is why I never looked at the thread.
Tuner codes are worthless, p,c, b and u codes are the only valid dtcs. The after market and banks in particular just adds mayhem. If you keep reading the rest and post back up with the info I will try to follow back up.
Second check the dlc with a test light. Any power?
3rd you dont say what year it is?
Next check terminating resisters... do a search I have explaind it a few times.
Disconnect the suspect connector and retest.
Do a network fault test.
Old 09-09-2014, 11:49 PM
Mustangoutcast
Thanks anyway
Sorry I forgot a few things, it is a 2003.
I gave up and took it to the ford dealership. There was an Internal short in my fuse box module.
First I didn't know a fuse box was a Module
Second what was in the back that could short
Third I am grateful I got out for less than the Obligatory $1000 bill.
I realize this site is quite polarized when it comes to tuners and such. But for the most part I have found it quite helpful in the past.
I hope this can be of help to someone in the future.
Thanx
Old 09-10-2014, 06:03 AM
bismic's Avatar
bismic
bismic is online now
Received 2,487 Likes on 1,724 Posts
Glad you got it fixed and thanks for posting the outcome.
I am surprised at the statement in bold though. You did have people wiling to help. Mustang_309 suggested a few things and you didn't even acknowledge his suggestions. Pretty much the same w/ cheezit. That coupled with the the fact that solving electrical problems over the internet is a pretty tall order to expect from folks. From what I have seen, oddball electrical problems (especially an intermittent short, etc) are most often solved by having people with good electrical troubleshooting skills right there with you (ie the internet responses may or may not help). Nature of the beast.
Cgl45
01-14-2016 05:42 PM
PlatinumPSD
03-01-2013 08:30 PM
tcrane
08-31-2010 11:50 PM
mikewrt
02-19-2004 09:23 AM
fast_eddy
1978 - 1996 Big Bronco
06-22-2002 09:52 PM
Quick Reply: No crank , no start Banks IQ W/six gun
