Smoke from valve cover?
Old 07-31-2014, 09:18 PM
mo76's Avatar
mo76
mo76 is offline
Hi. I have a small amount of smoke coming from the opening where, what I think is a breather tube, after changing my valve cover gaskets. Any ideas as to why? Thank you!
Old 07-31-2014, 09:22 PM
fmc400's Avatar
fmc400
fmc400 is offline
MSEE
Smoke coming from the breather means the engine is producing more blowby than the PCV valve can take in. Either the PCV valve can't pass, or the rings are worn. That wouldn't have started with the valve cover gaskets having been changed.
If it truly started with the valve cover gasket change, then maybe some oil got somewhere and is burning off. One or the other.
Old 07-31-2014, 09:30 PM
mo76's Avatar
mo76
mo76 is offline
Awesome. That is very helpful. I will check. Thank you!
bert cook
10-29-2014 07:53 AM
cutlass
09-21-2012 01:02 AM
ranger714
09-06-2008 05:10 PM
str8-6
05-31-2008 01:48 PM
muddyford75
07-27-2005 05:27 PM
Quick Reply: Smoke from valve cover?
