Biodiesel - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Biodiesel
Old 07-31-2014, 08:49 PM
slowmans's Avatar
slowmans slowmans is offline
slowmans has a good reputation on FTE.slowmans has a good reputation on FTE.
Biodiesel
So I am a big supporter of Biodiesel. I have been running it for years at a range of B-20 to B-50 in my 6.4 and also in my 6.0. I have recently started running B-99 for the last 4-5 tanks and I must say the truck loves it, its quieter, smoother and the mileage ( hand calc'd) is about .4 mpg better! I have access to a supplier that is very well known and has 2 pumps for Bio, B-20 and B-99. The current price average is about 3.75 for pump diesel here in southern MA, I buy my Bio at T.H Malloy in Cumberland RI and their price for B-20 is 3.74 and B-99 is 3.64.
Old 08-01-2014, 05:58 AM
senix's Avatar
senix senix is online now
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
Just be sure you change your oil and filters on time.
You're deleted right?
Old 08-01-2014, 10:21 AM
rock_doctor's Avatar
rock_doctor rock_doctor is offline
rock_doctor is starting off with a positive reputation.
Yea i honestly would not run bio in an emissions 6.4. The flash temp for the bio is higher then diesel and therefore the bio does not completely vaporizes during the regen exhaust stroke injection. This means more fuel is staying in liquid form which then washes down the cylinder walls and goes into the oil. Now with that said, if you are dpf deleted that eliminates the exhaust stroke injection and negates the problems with bio. So if you live in an area that does not emissions test i would suggest investing in deleting the dpf and then run as much bio as you want. If you still have the dpf then i would limit the amount of bio to 5 or 10% and change the oil and fuel filters religiously. The 6.0 will do fine with bio just keep up with the fuel filters. There use to be a very extensive article on a major biodiesel website but it magically disappeared and is no where to be found...
Old 08-01-2014, 02:52 PM
slowmans's Avatar
Its all good in the hood
B99 in a 6.7? Supercab 6.7L Power Stroke Diesel 10 08-09-2016 01:19 PM
Commercial Bio-Diesel in a 6.7?? Supercab 6.7L Power Stroke Diesel 6 06-27-2013 07:44 PM
6.4 on Bio-diesel DynamoDale Bio-diesel, Propane & Alternative Diesel Engine Fuels 3 03-01-2012 12:00 AM
The Big Biodiesel Scam!!!!! archangel Bio-diesel, Propane & Alternative Diesel Engine Fuels 29 04-18-2010 09:45 PM
Bio-diesel ? Mnytalks1 6.4L Power Stroke Diesel 4 04-17-2008 06:40 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
