94 f150 wont shift out of park???? - Ford Truck Enthusiasts Forums
Old 07-31-2014, 08:06 PM
matt.likes matt.likes is offline
matt.likes is starting off with a positive reputation.
was pulling a load the other day and when i got to the disposal site and started the truck up and poof wouldnt shift out of park. ABS light was flashing and had no brake lights. Found that the brake light fuse was blown in the fuse panel and swapped it out with the radio fuse and poof fixed the issue and it shifted. Now the fuse isnt blown but it still wont shift out of park. anyone had this issue before??? what sounds like the issue or the problem cz in a little dumbfounded by it. Thanks
Old 08-02-2014, 10:33 AM
F350 1990's Avatar
F350 1990 F350 1990 is offline
F350 1990 is starting off with a positive reputation.
Quote:
Sounds like you have a persistent / hung (e.g. CM) 536 type code (Brake on/off) ........try clearing the EEC-IV of codes by disconnecting the battery for 10 minutes (if this doesn't work I'll give you other options).............
Old 08-02-2014, 10:57 AM
1995F150XLT4x4's Avatar
1995F150XLT4x4 1995F150XLT4x4 is offline
1995F150XLT4x4 is gaining momentum as a positive member of FTE.
Sounds like the brake light switch directly under the steering column, or a wire leading to it. I had this exact issue awhile back, my truck would not come out of park so I had to turn the key once, and start it in neutral with my foot on the brake. My ABS light was on, too.
When this stop lamp switch goes bad, your truck thinks you don't have your foot on the brake, and won't let you go through the column gears. I replaced mine and that fixed the shifting out of park issue, but because I had a bad crimped wire going to it I had to replace the wire as well in order for my brake lights to work again. But in your case it might only be the switch itself.
Not sure if this is what's wrong, but that's exactly what I needed to do when my truck did this. Here's a link to the part. They're cheap & install in 5 minutes. Good luck!
MasterProŽ Ignition 2-8693 - Stoplight Switch | O'Reilly Auto Parts
Can't Shift from Park. #15 Fuse Blown IWPhoto Modular V8 (4.6L, 5.4L) 1 10-29-2016 08:47 AM
radio dead with power zherxies 2007 - 2014 Expedition & Navigator 1 10-28-2015 02:17 PM
02 supercrew wont shift out of park srpservices 1997 - 2003 F150 13 10-17-2015 08:36 AM
Trailer wiring heartache! Help! EYEDEYE 1987 - 1996 F150 & Larger F-Series Trucks 8 03-11-2015 11:11 AM
Engine sputtering and "POOF" sound when cold jsutton Fuel Injection, Carburetion & Fuel System 4 11-12-2013 08:12 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
