thinking about a sas.... pro/con - Ford Truck Enthusiasts Forums
Old 07-31-2014, 05:23 PM
roadrash63's Avatar
roadrash63 roadrash63 is offline
roadrash63 is gaining momentum as a positive member of FTE.roadrash63 is gaining momentum as a positive member of FTE.
Hey
im also thinking about a sas...
looked at one off an 89 f350
Ideas comments...
Wanted to do it on my old f150.
Much easyier on my f250 !
Old 07-31-2014, 07:03 PM
hav24wheel's Avatar
hav24wheel hav24wheel is online now
hav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputation
Not needed if not going bigger than a 33-35 inch tire IMO.
Why fix what's not broke.
Old 08-01-2014, 03:57 AM
tjc transport's Avatar
tjc transport tjc transport is offline
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
it is a bolt in deal, but make sure you get EVERYTHING that touches the axle, from springs to steering components.
Old 08-01-2014, 05:37 AM
Rovernut's Avatar
Rovernut Rovernut is offline
Rovernut is gaining momentum as a positive member of FTE.Rovernut is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by roadrash63 View Post
Hey
Ummm...
due too very low budget im looking at the badlands 12000 winch.
I think you're getting ahead of yourself. Don't loose focus, maybe make a list in order of priority.
Must have
Would be nice to have
Would be fun to have
Would look cool to have
Then think about where your money is going to better spent..
Old 08-01-2014, 08:07 AM
LeoJr's Avatar
LeoJr LeoJr is offline
LeoJr has a good reputation on FTE.LeoJr has a good reputation on FTE.
I just did this recently, but I spent a lot of time doing things in advance so the actual swap was rather quick and painless. Was it worth the work? Most of the benefits will come long term as my alignment issues are mostly resolved, I get some lift due to the F350 springs and can run 35s using a cut or aftermarket bumper, and the steering radius is tighter.
Old 08-01-2014, 09:08 PM
roadrash63's Avatar
Yeah a long range plan.
Maybe next winter...
i just love a strait axle !
Says a real 4x4.
Old 08-19-2014, 09:14 PM
totalloser totalloser is offline
totalloser is starting off with a positive reputation.
Not worth the hassle for a "trail rig" unless you plan on locking it. AND getting rid of, or upgrading the spline count on your rear.
Here's how I'd go at it:
Minor build for cheap: find a sterling 10.25 or 10.5" with a limited slip and repack it. Crazy easy to find for cheap. I see them regularly for about $200 and they are ***way*** more durable than the dana rear unless you upgrade to 35 spline in it.
Slightly better capability: find a sterling rear and put a ratchet locker in it *not a lunchbox* if you want better handling and better durability.
Good offroad capability: Sterling rear with ratchet locker, dana 60 with ratchet locker and possibly 35 spline stubs and hubs.
I wouldn't even consider the hassle of live axle up front unless you need a locker in the front.
Old 08-20-2014, 12:11 PM
Nothing Special's Avatar
Nothing Special Nothing Special is offline
Nothing Special has a great reputation on FTE.Nothing Special has a great reputation on FTE.Nothing Special has a great reputation on FTE.Nothing Special has a great reputation on FTE.Nothing Special has a great reputation on FTE.
Big discussion on this on the '87-'96 forum recently, regarding the swap in a work truck. A lot of that discussion is very relevant to a trail rig as well though if you're interested in plowing through it: http://www.ford-trucks.com/forums/13...y-options.html
Is there anything to be gained? Yes. Is it worth the cost, and what other mods are better bang for the buck? Up to you.
Axle strength:
A D60 will have stronger shafts than a TTB D50. But as others have said, the D50 shafts are plenty strong unless you add a locker (and even then aren't clearly too weak.
Clearance for bigger tires
Not a factor if you aren't planning to install bigger tires. But you get about a 3" lift putting a D60 in, and lifting it even more than that is pretty straightforward. Of course you can lift a TTB as well, but the money you spend on a TTB lift would go quite a ways toward a SAS with more benefits.
Wheel travel
You will likely get more front wheel travel out of any SAS. You definitely can get more if you are trying for it. Then again, lack of wheel travel wasn't much of an issue when I fourwheeled my '85 F-250. It had so much frame flex that it always kept all 4 tires on the ground anyway.
Better ride
This would be the biggest benefit for me. The leaf spring TTB is STIFF. if I were doing an SAS on a trail truck I'd go with custom springs with a lower spring rate than standard F-350 springs. But most people say that even F-350 springs on an SAS ride better than a leaf spring TTB (not everyone agrees with that though). Trail running in my '85 F-250 was brutal. I had to crawl any trail that was any rougher than a decent gravel road. Having a softer front (and rear, but especially front) suspension would have made trail running a lot more fun in that truck.
SAS and leaf spring lift question dtgl90vt Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 26 05-16-2016 05:15 PM
1985 F250 SAS Suspension Joe Red 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 8 05-07-2016 02:41 PM
Sky shackle reversal on older trucks oneofakind97 Offroad & 4x4 1 08-11-2014 06:59 PM
fabritech sas Muddr Trukkr Offroad & 4x4 20 08-19-2004 10:31 PM
Know any one who ever wheeled with a Fabritech SAS ? az4x4bronc Offroad & 4x4 10 06-12-2004 06:44 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
