Fuel Pump, 89 F250, 7.5 - Ford Truck Enthusiasts Forums
Old 07-31-2014, 04:32 PM
erica erica is offline
erica is starting off with a positive reputation.
Question Fuel Pump, 89 F250, 7.5
Our in-tank fuel pump was replaced last summer. I know that when you turn the key on you should hear the pump hum and do its thing. How long should you hear this humming sound?
Old 08-02-2014, 12:47 AM
kevin206's Avatar
kevin206 kevin206 is offline
kevin206 is starting off with a positive reputation.
I hear mine for 3-5 seconds when I turn the key on.
Old 08-02-2014, 08:16 AM
subford's Avatar
subford subford is online now
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
The timer is for one second but one second is longer than most think.
If longer than one second it may mean the caps are starting to go. In other words it is taking the clock a second or so to get going.
If the clock does not start then the fuel pumps will continue to run and the fuel injectors will not be grounded (or fired) by the computer.
loud humming noise buddy316 Expedition & Navigator 3 12-10-2015 10:12 AM
Fuel tank transferring fuel bowgutshot 1987 - 1996 F150 & Larger F-Series Trucks 10 04-21-2015 10:51 PM
1986 f250 rear fuel pump humming? emag 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 0 05-20-2014 06:50 PM
humming fuel pump? powerstroke451 6.7L Power Stroke Diesel 3 08-20-2013 03:12 PM
84 f250 not hearing fuel pump lovinmytruck 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 19 02-21-2010 10:56 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
