Should I bother painting engine valley? - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 07-31-2014, 04:21 PM
timmygyu timmygyu is offline
timmygyu is starting off with a positive reputation.
I've been working on rebuilding my fuel filter/water separator assembly. At this point, I've got everything out so I can see the engine valley real well. It's pretty rusty. Is there any point in painting it? I don't care about cosmetics; I'm just wondering if I should be worried about the rust.
Old 07-31-2014, 07:37 PM
tshrager's Avatar
tshrager tshrager is online now
tshrager has a good reputation on FTE.tshrager has a good reputation on FTE.tshrager has a good reputation on FTE.
Quote:
If the block is so rusty it's eating itself, you've got bigger fish to fry. Is the rust eating anything else?
Old 07-31-2014, 08:01 PM
Hussler's Avatar
Hussler Hussler is online now
Hussler is a name known to allHussler is a name known to allHussler is a name known to allHussler is a name known to allHussler is a name known to allHussler is a name known to all
Can't imagine anything rusting up top on the engine, unless it was sitting outside for a long period of time. If it was me I certainly would clean it up since it is accessible and throw some paint on it.
Old 07-31-2014, 10:46 PM
oldbird1965's Avatar
oldbird1965 oldbird1965 is online now
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
Personally, I feel good about a rusty valley! That means that nothing is leaking, LOL
Old 07-31-2014, 10:50 PM
ReBilld's Avatar
ReBilld ReBilld is offline
ReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to behold
Quote:
You have a good point there!!!
Old 08-01-2014, 08:02 AM
OldWoodsDiesel's Avatar
OldWoodsDiesel OldWoodsDiesel is offline
OldWoodsDiesel is gaining momentum as a positive member of FTE.
i can't imagine its that rusty up there. the engine i'm rebuilding was rusty as anything on the outsides of the block and head from being in a plow truck for 200k miles. once all the crud and gunk was cleaned out of the valley i was surprised to see the factory paint was still good as new underneath it all.
the only things that should wind up in the valley are diesel fuel and engine oil - both of which will hold on to crud like its their job, but also prevent rust. ...like its their job.
Old 08-01-2014, 08:06 AM
The only time my valley was rusty was when my water injection nozzle broke and sprayed water all over.
Old 08-01-2014, 09:14 AM
sounds like you didnt have enough oil leaks before that water leak happened! :-)
Old 08-01-2014, 11:09 AM
paddler paddler is offline
paddler is starting off with a positive reputation.
White paint for visibility?
Might consider white paint (oil & gas resistant, if you can find it) while everything is apart. White background is easier to see things (dropped parts, leaks) against, and reflects some light back into the engine bay. Better than a dingy, dirty background.
I spray-bombed my valve covers white when I had them off to do UHVC & glow plugs; the white background helps when I have other things to see & find.
Old 08-01-2014, 03:24 PM
Quote:
No, I had electric fuel so could clean it all up and keep it that way. When I'm checking things over, that's one thing I look at. In the past I had plenty of leaks in there, especially before e fuel.
Old 08-03-2014, 04:15 PM
7[c[Z{Avfyg/
Heh, guess I flaked out on this post Thanks for the feedback, everyone. Posting an image of my valley below; whatcha' think?
Old 08-03-2014, 10:17 PM
Nothing wrong with that valley! If you want to paint it, now is the time.
valley cover with PVC port 60F100HD 1957 - 1960 F100 & Larger F-Series Trucks 3 06-23-2015 03:07 PM
Oil in the valley, why? 351Cleveland C4 1999 - 2003 7.3L Power Stroke Diesel 16 03-14-2015 07:31 PM
Any usual suspects for this leak? Tailgate77478 1999 - 2003 7.3L Power Stroke Diesel 2 12-18-2014 07:38 AM
Turbo Pedestal Oil Leak Question disneyd 1999 - 2003 7.3L Power Stroke Diesel 1 04-14-2011 12:50 PM
Valley Pan Removal on NA 7.3 newr Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 2 03-10-2008 02:32 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
