Will 35s fit? - Ford Truck Enthusiasts Forums
Will 35s fit?
Old 07-31-2014, 03:48 PM
Ford205 Ford205 is offline
Ford205 is starting off with a positive reputation.
Will 35s fit?
I have a 2005 XLT, 4x4 F-150 with a Daystar 2.5 inch leveling kit, I have stock 17 inch wheels and I'm wondering if I can make the 35 fit? I heard wheel spacers might work, and I don't really wanna take the fender flare route.. I was thinking about getting new wheels with a different offset. any suggestions?
Old 08-02-2014, 12:16 AM
papasmurf40's Avatar
papasmurf40 papasmurf40 is offline
papasmurf40 is starting off with a positive reputation.
35's will fit, but if you have stock gearing, especially 3.55:1 gears, i think you would be happier with 33's. Real knobby or aggressive 35's may require trimming but should fit on your stock rims.
Old 08-04-2014, 08:51 AM
tjcprop's Avatar
tjcprop tjcprop is offline
tjcprop has a very good reputation on FTE.tjcprop has a very good reputation on FTE.tjcprop has a very good reputation on FTE.
The turning radius will be less. The tires might rub inner wheel wells. If the tires stick out slightly this will cause the doors, mirror to always get dirty from tires without flares or larger mud flaps.
Wheel and Tires advice! Help please! 6.4spartan 1999 to 2016 Super Duty 1 02-18-2015 06:27 PM
Tire/Wheel fit? mrseventhree 1999 - 2003 7.3L Power Stroke Diesel 4 02-11-2015 10:11 PM
Dully wheels fit jchamb11 1999 - 2003 7.3L Power Stroke Diesel 2 09-30-2013 06:26 AM
Rim size Scoop531 1973 - 1979 F-100 & Larger F-Series Trucks 4 04-09-2007 03:13 PM
35's on a 82 f250 4beer4 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 21 06-17-2004 04:51 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
