electrical problems - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
electrical problems
Old 07-31-2014, 01:52 PM
nickjohnson450 nickjohnson450 is offline
nickjohnson450 is starting off with a positive reputation.
electrical problems
i have a 2009 f-250 king ranch 4x4 with a 6.4L. i have been having a series of electrical problems with no luck locating a source. Current problems: windshield wipers will not work at any selection, blower motor inside cab for a/c and heat will not come on, headlights in auto mode will turn on and off rapidly during daytime, speedometer will bounce when stopped and while driving at random times, when using keyless entry to unlock truck my side mirrors starting adjusting outward. i have checked fuses, relays, random wire bundles. any suggestions at this point would be greatly appreciated.
Old 07-31-2014, 01:55 PM
David7.3's Avatar
David7.3 David7.3 is offline
David7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to behold
Did the body module get wet at all? everything ties into that module, I had a leak in my windshield which lead down to the kick panel and had to have it replaced, dealer only cause it has to be programed for your truck or VIN I should say.
Old 07-31-2014, 02:10 PM
electricla problems
The body module did not get wet that I am aware of. I have a feeling that it is a device that all of these componenets all go back to.
Old 08-13-2014, 11:22 AM
kenster kenster is offline
kenster is starting off with a positive reputation.
if there's water coming in
this square is behind the fuse panel,when parked on a hill ,water ran in and caused a real mess with my electrical system.From what u talked about to a no crank ,no start problem,and codes out my a$$.
this hole was to be covered at factory,drivers side was covered but not this side.should trim the tape.
hope this might help,worked great for me..
hope this works,never done this before.
Tailight Electrical Issues sharikmate 1978 - 1996 Big Bronco 4 08-15-2015 04:44 AM
Electrical problems 2000 f250 Casey blue 1999 - 2003 7.3L Power Stroke Diesel 1 03-03-2015 06:13 PM
electrical problems 86f250XLT-4x4 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 5 12-10-2014 12:56 AM
2003 Expedition Electrical Gremlins CMWSR Electrical Systems/Wiring 1 07-11-2014 09:30 AM
04 escape electrical problems happyjay9 Escape & Escape Hybrid 0 06-21-2014 02:01 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
