Cooling System - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Cooling System
Old 07-31-2014, 09:23 AM
irsparki's Avatar
irsparki irsparki is offline
irsparki is starting off with a positive reputation.
Cooling System
I have a 2008, 6.4, F350, just recently had the radiator hoses replaced and t-stats at a dealership. I asked the rep if distilled water was used, his answer "No, we do not use it, we have not had any problems. " My question is will I ? Thank you in advance for your replys.
Old 07-31-2014, 02:52 PM
senix's Avatar
senix senix is offline
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
They might have used the pre-mix stuff. Ask again.
Old 07-31-2014, 10:43 PM
pstroke67 pstroke67 is offline
pstroke67 is gaining momentum as a positive member of FTE.
Quote:
Yes you will have problems ford only let's us use distilled water ro water or ultra low chlorine tap water on superduty cooling systems if tap water was used what will eventually happen all that hard minerals will eventually plug the oil cooler wich will set wrench light and de rate power This is a tsb that has information on water usage
*Printable View (66 KB)
TSB
10-12-1
6.0L/6.4L DIESEL - WATER QUALITY WHEN SERVICING COOLING SYSTEM
Publication Date: June 10, 2010
FORD:
2003-2005 Excursion
2003-2010 F-Super Duty
2004-2010 E-350, E-450
ISSUE:
Use of tap water in some geographic areas or municipalities can lead to unacceptable scaling and/or corrosion protection of the cooling system, as well as decreased coolant pump life.
ACTION:
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
Prior to using available tap water for the final flush of a cooling system, verify the water quality is acceptable using water quality test strips Rotunda part number 328-00007.
Collect about 8 oz. (237 mL) of tap water in a clean cup. Water sample temperature must be between 50 F (10 C) and 130 F (54 C).Remove test strip from the foil sealed packet. Do not touch the pads at the end of the strip.Dip the strip in the water sample for five (5) seconds with a gentle back and forth motion. Remove the strip and shake briskly to remove excess liquid.Twenty five (25) seconds after dipping the strip, compare the pads with the color chart included in the test kit in the following order. Record results.Hardness level (end pad)pH level (middle pad)Chloride level
All three readings must be completed no later than thirty five (35) seconds after dipping the strip.
If tap water does not meet the pass criteria for hardness, pH and Chloride, one of the following alternatives should be used for the final flush of the cooling systemistilled water. Distilled water is required for diluting coolant concentrate.Deionized water.Purified water from a reverse osmosis water filter system
My First Build, 66 F100 tedrowtr13 1961 - 1966 F-100 & Larger F-Series Trucks 35 07-27-2016 01:12 AM
1990 F150 Electrical Issue farmtruck101 1987 - 1996 F150 & Larger F-Series Trucks 1 07-16-2015 08:33 AM
Soon to be RVers Looking for Truck/Trailer advice WayneinChatham Aftermarket Products 5 05-22-2015 01:03 PM
New RVers Needing Advice WayneinChatham Fifth Wheel & Gooseneck RV Towing 16 03-14-2015 07:35 AM
1988 ford f150 alternator 97 ford jacked up 1987 - 1996 F150 & Larger F-Series Trucks 1 05-26-2014 06:47 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
