An Engine Rebuild/Refresh Thread - Page 5 - Ford Truck Enthusiasts Forums
  #61
Old 08-20-2014, 09:13 AM
OldWoodsDiesel's Avatar
OldWoodsDiesel OldWoodsDiesel is offline
OldWoodsDiesel is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by williameub View Post
Still interested in that dipstick adapter....
ok, i'm behind on my picture posting and updating, but i have been making progress. work's just been crazy.
i have a quick question for you all though:
should i replace my current powersteering pump while i have the bracket off, or are these things relatively tough. it has 200k on it, but have never given me problems. i know the reservoir leaks, but i assume there's a re-ring kit or something for it...
  #62
Old 08-20-2014, 07:02 PM
427 fordman's Avatar
427 fordman 427 fordman is offline
427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.
Your call JP. If it worked fine, I'd be trying to stop the truck from swallowing too much money at once... Not that hard to change later if need be.
  #63
Old 08-20-2014, 10:46 PM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE MOOSE_MACHINE is online now
MOOSE_MACHINE has a good reputation on FTE.MOOSE_MACHINE has a good reputation on FTE.
I agree. I'm only replacing mine case it's leaking out the front seal. No sense putting one that's on it's way out back in. But if yours looks good I'd still run it
  #64
Old 08-21-2014, 11:24 AM
Quote:
exactly my thinking! i kind of want to pull it off the bracket to paint the bracket up. the rest of the engine is looking so good that it feels wrong to put that dirty part back on there...
Quote:
yeah, it never gave me any problems - other than blowing the high pressure fitting off one time - but that wasnt the pump's fault, the hose itself separate!
anyone have a quick how-to on the removal of that sucker, though? looks like an allen wrench will fit in the pump shaft, but doesnt look like the pulley will just spin off if you hold that shaft still. or will it?
the shop manual procedure is greek to me:
Removal
Remove the drive belt (8620).
On some vehicles, it may be necessary to remove the fan shroud (8146) to allow for proper installation and operation of the power steering pump pulley remover tool. Refer to Section 03-03.
Install Steering Pump Pulley Remover T69L-10300-B on the hub of the power steering pump pulley (3A733).
NOTE: Do not apply pressure on the power steering pump rotor shaft (3B559). Pressure will damage internal thrust areas of the power steering pump (3A674).
While holding the nut of the remover tool stationary with a wrench, rotate the inner spindle of the remover tool clockwise until the power steering pump pulley is pulled off the power steering pump rotor shaft.
  #65
Old 08-21-2014, 12:48 PM
dclack's Avatar
dclack dclack is online now
dclack has a good reputation on FTE.dclack has a good reputation on FTE.
The pulley is press fit on, not threaded. You need this tool remove/install the pulley... Power Steering Pulley Puller/Installer | AutoZone.com
  #66
Old 08-21-2014, 02:09 PM
DIYMechanic's Avatar
DIYMechanic DIYMechanic is offline
DIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to behold
^^2x but you can remove the pump from the bracket without removing the pulley. You can't get the bolts all out of the pump, but the pump will come off the bracket, you just have to reach through the holes in the pulley with a socket to unbolt it.
  #67
Old 08-21-2014, 05:15 PM
Quote:
thanks D...
Quote:
but that sounds like a better option! i'll just take the pump off, clean it up and paint the bracket. i'll have to do more staring (and maybe wipe some grime away) to see exactly how it comes off, but i trust you Nate :-)
  #68
Old 08-21-2014, 05:48 PM
dclack's Avatar
I'll have to trust him too because I've never worked on a 7.3 PS pump. i just know that on the gasers you DO have to pull the pulley because the bracket makes a complete circle and there is no way to separate the pump and bracket with the pulley on.
  #69
Old 08-21-2014, 05:52 PM
My psd is the same way. Pull the pulley to remove the pump
  #70
Old 08-21-2014, 09:32 PM
That's kind of what I thought mine was like too. No chance to work on the truck tonight so I'll have to check tomorrow.
Any chance it's an early vs late obs psd thing? The engine I'm working on is a 96...
  #71
Old 08-21-2014, 10:01 PM
dclack's Avatar
I just looked at my '97 and there is no way the pump is coming off without pulling the pulley.
Oh, and thanks for asking this and prompting me to go look, cause this is what I found...
Guess I need to get a wrench on that!
  #72
Old 08-22-2014, 12:13 AM
I just looked at my '97 and there is no way the pump is coming off without pulling the pulley. Oh, and thanks for asking this and prompting me to go look, cause this is what I found... Guess I need to get a wrench on that!
When I pulled mine it was the same way. I was thinking about putting in a mild loctite but also don't want the headaches when I have to pull it next time
  #73
Old 08-22-2014, 07:04 AM
I bet I'm thinking of the vacuum pump. Sorry if I misled you. My head is so full of stuff sometimes the wrong thing falls out when I rattle it, lol.
  #74
Old 08-22-2014, 08:03 AM
I find a good hit to the back of the head is more accurate lol
  #75
Old 08-22-2014, 09:08 AM
no worries, Nate. i didnt put any work into it anyway. now i need to decide if i want to pull it just to clean the bracket or not. judging how far behind i am against where i wanted to be now, i have a feeling its staying.. plus its an aluminum bracket, so while it may look like crap right now, it won't ever rust badly...
i will check to make sure those bolts aren't loose, though!
like a good hit to the back of the head on a frame rail? or axle when working under the truck? that never happens!
Changing JUST shocks (but not springs) on a 2007+ (3rd Gen) Expedition sfc2001 2007 - 2014 Expedition & Navigator 18 09-19-2016 08:59 AM
This is neat. Bently_Coop 1999 to 2016 Super Duty 4 03-08-2016 10:38 AM
Width + Height = Plus Size 2LostInTransit Transit Connect 41 10-17-2015 08:07 PM
Doors (sound deadening) Tom-N Vendor Specials, Discounts, Product Announcements & Group Buys 0 10-13-2015 04:41 AM
My 97 F-350 Rebuild/Repaint Thread OldWoodsDiesel 1994.5 - 1997 7.3L Power Stroke Diesel 282 03-31-2015 12:59 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
