My back fuel tank does not work any more. The sending unit is working but no fuel to the motor. Can some one please send me a link on how to troubleshoot this? I cant seem to find any fuses or relay in my manual.
There are two possible items that could be wrong. If the wiring and plugs are good then you either have a bad fuel pump selector switch in the dash or a bad fuel pump.
Unplug the rear fuel pump and check the Brown wire with a white stripe at the plug on the drivers frame near the tank.
