Turbo surging in 4th gear only - Ford Truck Enthusiasts Forums
Old 07-30-2014, 08:41 PM
2006powerstroke90's Avatar
2006powerstroke90 2006powerstroke90 is offline
2006powerstroke90 has a great reputation on FTE.2006powerstroke90 has a great reputation on FTE.2006powerstroke90 has a great reputation on FTE.2006powerstroke90 has a great reputation on FTE.
When I am driving down the highway my turbo will surge. I can watch it on the gauge going from 25 down to 20 and right back up it will do this until I let off or change gears.
Is this normal for a stick shift?
Changed the fuel filters and nothing changed. Thanks.
Old 07-30-2014, 09:17 PM
9228.bobcat's Avatar
9228.bobcat 9228.bobcat is offline
9228.bobcat has a great reputation on FTE.9228.bobcat has a great reputation on FTE.9228.bobcat has a great reputation on FTE.9228.bobcat has a great reputation on FTE.
Sounds as if the vgt and or turbo needs cleaned.
Old 07-30-2014, 09:32 PM
04badford 04badford is offline
04badford has a brilliant future04badford has a brilliant future04badford has a brilliant future04badford has a brilliant future04badford has a brilliant future04badford has a brilliant future04badford has a brilliant future04badford has a brilliant future04badford has a brilliant future04badford has a brilliant future04badford has a brilliant future
Can you monitor VGT , MAP, EBP ? do have EGR or delete
Old 07-30-2014, 10:35 PM
cheezit's Avatar
cheezit cheezit is offline
cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.
Unplug ebp. Does it still happen? If so suspect bad vgt sensor. Swap in kowen good one to test.
Old 07-31-2014, 03:09 AM
Yahiko's Avatar
Yahiko Yahiko is offline
Yahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputation
Stiction only (mostly) happens when the engine is cold.
Once you have warmed up it goes away. It's more like
a miss or ruff idle.
Sean
Old 08-01-2014, 08:12 AM
Would there be something electronic causing this?
I tried it again on the highway last night, all gears pull perfectly besides 4th...
If I have to pull the turbo I will, but id prefer not to!
I will pull the EBP sensor today before I head home and see what happens
Old 08-01-2014, 02:32 PM
Yahiko's Avatar
Go with with what Cheezit said.
Sean
Old 08-01-2014, 08:18 PM
don't pull it just unplug the connection
Old 08-05-2014, 07:47 AM
Took out the EBP sensor, thing was plugged solid, cleaned it and no more surging
Old 08-05-2014, 09:36 AM
Glad you got it fixed. And thanks for coming back and posting what resolved the issue. That cheezit seems to know what he is talking about.lol
surging problem mrcmbenton EcoBoost (all engine sizes) 15 02-03-2012 10:04 AM
slight throttle surge Franko72 1999 - 2003 7.3L Power Stroke Diesel 31 06-22-2011 11:15 AM
Trans Shifting and Turbo Surge? snakedoc 1999 - 2003 7.3L Power Stroke Diesel 11 08-07-2010 09:56 PM
Surging? deercreek1 6.0L Power Stroke Diesel 9 05-04-2010 08:48 PM
What does turbo surge sound like? Robert6401 1999 - 2003 7.3L Power Stroke Diesel 7 02-21-2010 09:45 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
