valve stem seal?
I think you are asking people who don't have enough info to give a reasonable answer. But the classic signs of valve stem seal leaks is a puff of smoke when you start up, and smoking when you let off the gas, like when going down a long hill. In startup the smoke comes from burning oil that ran into the cylinders with engine off. In coasting it comes from very high vacuum in the cylinders sucking oil past the guides and seals. So, is that when your engine smokes?
Here's a link to an overview of internal combustion engines. Page 16 has a cutaway drawing and Item D is the valve guide, which is the relatively soft piece that is pressed into the head and which "guides" the valve to center up in the seat. These wear and allow the valves to rock as they close and that frequently prevents the valve from seating correctly in the head. That allows leakage and that then allows the valve to burn if it is an exhaust valve. In addition, the rocking causes excessive wear in the seals.
So, just replacing the seals might be short-lived if the guides are bad. And bad guides can lead to burned valves. But, frequently the rest of the engine is well worn when the guides go. So, don't fix one thing without finding out the condition of everything as it can easily be a fruitless exercise.
krazyness
07-02-2016 12:58 AM
brthevio
05-26-2008 09:02 PM
