Driving without hub lockers?
I have a steering problem that I am working through that sounds similar to the problems described in this thread:
https://www.ford-trucks.com/forums/1...g-problem.html
I'm replacing ball joints and u-joints on the front axle. I finished the passenger side and am starting in on the driver's side.
On the driver's side, I found that the internals of one of my Warn premium hub lockers was broken. One of the main gears has shattered inside of the hub. I spoke to Warn and they are willing to replace the piece under warranty but want me to send the pair of hub locks back to them before they'll send out the replacements.
The question is: what are your opinions on driving the truck without the hub lockers in place? It seems like the hub locker provides some non-negligible support to the axle stub. Without the locker in place, I worry that too much stress will be placed on the 4wd needle bearings. Maybe I should try to find a used/broken pair or devise some other "dummy" piece to slap in there while I wait for the warranty turn-around.
What do you think?
What do you think?
Exactly! Make sure you have some sort of hub in there to hold that shaft in place. There seems like there is very little movement when you grab it with your hand but driving down the road at 70 is whole different thing. I just went through this driving without guts inside the hubs and when the shaft finally moved enough it started spinning even though the 4x4 wasn't engaged and then it caught the grease zerks. When that happened it felt like the whole front end was coming apart going down the road. Not fun at interstate speeds. It had wore on the outer shaft so much I had to replace that and the bearings, seals and hubs. Gets expensive and that was not paying labor as I did it myself.
queen of spades
1999 to 2016 Super Duty
03-22-2015 04:38 PM
FreeDevin
15
10-31-2011 05:13 PM
