Heated Transmission Fluid Flush - Ford Truck Enthusiasts Forums
Pennsylvania Chapter Join Chapter, Leader: liftnw8z
Old 07-30-2014, 12:36 PM
CollinsCD's Avatar
CollinsCD CollinsCD is offline
CollinsCD has a good reputation on FTE.CollinsCD has a good reputation on FTE.CollinsCD has a good reputation on FTE.
My 2010 SuperDuty has the TorqShift 5R110W trans that has the internal temp regulator that limits the external flow to the cooler until the fluid reaches ~160 so normal flush machines won't work. Ford states that you need the heated fluid flush machine in order to remove all the old fluid. I have been calling dealers in my area and no one has one of these heated trans flushers. Does anyone know of any area shops who do the heated fluid flushes?
Heated Transmisson Fluid Change CollinsCD Delaware Chapter 0 07-30-2014 12:02 PM
2010 Super Duty Transmission Service CollinsCD 1999 to 2016 Super Duty 5 03-20-2014 10:48 PM
Torque Shift Fluid Change super 6.8 Modular V10 (6.8l) 2 08-18-2012 08:52 PM
HEATED trans flush in Detroit/Downriver area? RickBraden Michigan Chapter 4 06-13-2012 11:09 PM
Torqueshift flush machine JimBrazil 1999 to 2016 Super Duty 6 11-14-2009 06:42 AM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
