Heated Transmission Fluid Flush - Ford Truck Enthusiasts Forums
Maryland Chapter Join Chapter, Leader: jr32560
Old 07-30-2014, 01:35 PM
CollinsCD's Avatar
CollinsCD CollinsCD is offline
CollinsCD has a good reputation on FTE.CollinsCD has a good reputation on FTE.CollinsCD has a good reputation on FTE.
My 2010 SuperDuty has the TorqShift 5R110W trans that has the internal temp regulator that limits the external flow to the cooler until the fluid reaches ~160 so normal flush machines won't work. Ford states that you need the heated fluid flush machine in order to remove all the old fluid. I have been calling dealers in my area and no one has one of these heated trans flushers. Does anyone know of any area shops who do the heated fluid flushes?
Old 07-30-2014, 08:07 PM
jr32560's Avatar
jr32560 jr32560 is offline
jr32560 is a splendid one to beholdjr32560 is a splendid one to beholdjr32560 is a splendid one to beholdjr32560 is a splendid one to beholdjr32560 is a splendid one to beholdjr32560 is a splendid one to beholdjr32560 is a splendid one to beholdjr32560 is a splendid one to behold
never even heard of such a thing~~~
that's crazy~~~
Old 07-31-2014, 07:06 AM
CollinsCD's Avatar
Quote:
that's crazy~~~
Do some research and you will see that the Super Duty transmissions have thermostats so normal flush machines won't remove all the old fluid.
Old 07-31-2014, 02:47 PM
BPofMD's Avatar
BPofMD BPofMD is offline
Posting Legend
BPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputation
He's right Jr. Craig, I just drop the pan and replace what I took out..... Just do it every 30,000 miles instead of once every 100,000. Keeps it nice an clean. Have you checked out the Super Duty forum? Lots are doing it this way.
Old 07-31-2014, 06:31 PM
dustybumpers's Avatar
dustybumpers dustybumpers is offline
Posting Legend
dustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputation
I talked to my trans guy, he stated that the trans is at operating temp when the transfer start, so you are pulling the trans fluid out it is at operating temp. He also stated that he heats the new oil that goes back in. Maybe not the designed method, but it works.
And as Bud stated, you still have to drop the pan and change the filter.
Old 08-03-2014, 05:55 PM
BPofMD's Avatar
Posting Legend
Actually, I DON'T drop the pan...it has a drain plug. The filter is located up under the front bumper - Passenger side. Yes, there is a filter inside the tranny pan but it so coarse that it only filters out things like boulders-refrigerators etc.
Hi Charlie...how's things going?
Old 08-03-2014, 09:55 PM
Greywolf's Avatar
Greywolf Greywolf is offline
Greywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputation
And THIS is supposed to be a "BETTER IDEA" ???
~Somebody get a rope...
Old 08-04-2014, 07:17 AM
BPofMD's Avatar
Posting Legend
I'm sorry they left out the drain plug for the converter..... one of Ford's "better" ideas. Someone thought that all the dealers would spring for that novel fluid heater!! Dealers are cheaper than the manufacturers!
Old 08-06-2014, 07:17 AM
CollinsCD's Avatar
On my 2010 Super Duty, Ford has the new improved filter in the pan and no longer has the external toilet paper filter. I bought the new filter from Ford and will drop the pan.
Old 08-06-2014, 07:18 AM
CollinsCD's Avatar
Yep, that is what I will do.
Thanks!
My Revised Torqshift Transmission Flush Procedure creator 1999 to 2016 Super Duty 16 10-11-2016 11:28 AM
Trans identification and service procedures? SoCalAngler Clutch, Transmission, Differential, Axle & Transfer Case 12 05-20-2016 08:23 PM
Heated Transmisson Fluid Change CollinsCD Delaware Chapter 0 07-30-2014 01:02 PM
Torque Shift Fluid Change super 6.8 Modular V10 (6.8l) 2 08-18-2012 09:52 PM
Does tranny filter need to be changed with tranny Flush? mrad Excursion - King of SUVs 13 11-08-2009 11:00 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
