How realistic is it to just tighten exhaust bolts?
So my 94 F250 with a 351 has a few loose exhaust manifold bolts... I can hear/ feel the leak on the passenger side. How much crack am I smoking to think I could just tighten them and get by for a while? I don't have the time to tear it down at the moment. I don't see any major long term damage from this.
Just torquing them will not do it as they are rusted in. you would need to loosen them and then torque them back to spec. If you do that you should just get a new set of bolts and put a gasket in. Figure out which side is leaking and just do that side for now.
Bolts and Gasket are cheap. I paid about $40 for both and got a descent gasket.
You guys are right that from the factory, there is not a gasket. However, after a few heat cycles, the metal is warped and will never seat right again if taken apart. Therefore, you need to put a gasket in if you remove the manifold, or if it comes loose. A good metal core gasket is a good idea. The cheaper paper gaskets wont last long and you'll be removing the manifold again.
OregonHighboy
09-04-2016 07:37 PM
F-250 WARHORSE
05-28-2013 09:28 PM
dr.west
13
11-30-2004 11:35 AM
canzus
09-05-2002 12:09 PM
