V10 running rough - Ford Truck Enthusiasts Forums
V10 running rough
Old 07-30-2014, 11:48 AM
DetailerDave's Avatar
DetailerDave DetailerDave is offline
DetailerDave is starting off with a positive reputation.
V10 running rough
After some repair work, my truck is running rough at times. High gear (OD) 55 mph or so, 1500 rpms, light throttle to accelerate, it feels like the engine wants to jump out from under the hood. Downshift, 2500 rpms, it is smooth as silk. I had the intake off, to replace the heater pipe underneath. When putting back together, I noticed the supply vacuum line to the EVR was broken. I repaired it, and my assistant insstalled the vac lines, fuel lines, etc. It was almost imposssible to see what you are doing, and I suspect my helper may not have put things back together correctly. The truck runs good in general, plenty power upon taking off from a light, etc, only when in high gear, low rpm, light throttle situation. I have tried to look at the vac connections, and it is impossible to see. Mirrors, lights, all to no avail. This weekend, I will try to perform a vac test on the lines, or else take parts back off to be able to see the EVR vac connections. Any other ideas are appreciated.
Old 08-25-2014, 11:08 AM
TIUSER's Avatar
TIUSER TIUSER is offline
TIUSER has a good reputation on FTE.TIUSER has a good reputation on FTE.
First I would suggest COPs. I am having the same problem right now, and mine has no compression in cylinder #5. Looking like it is valve and/or spring issue but again we are still working on mine. Hopefully you have the better luck than I have.
Major idle problem Brian Ski 44 1987 - 1996 F150 & Larger F-Series Trucks 2 08-25-2015 09:54 PM
timing question saauvenshine 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 04-07-2015 10:56 AM
EVR valve ltyler179 1987 - 1996 F150 & Larger F-Series Trucks 9 01-04-2015 11:55 AM
Rough Running V10 DetailerDave 1999 to 2016 Super Duty 6 08-03-2014 09:15 PM
Hesitation 73 360 Motorcraft Carb LFDavidson FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 25 09-30-2009 10:28 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
