Cold air intake, yes or no? - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis SPONSORED BY:
Old 07-30-2014, 11:05 AM
davalt75's Avatar
davalt75 davalt75 is offline
davalt75 is starting off with a positive reputation.
I have a 2010 F250 6.4 cc 4x4. The dpf and egr are deleted. I don't have a tuner but have had the truck flashed by 5 Star Tuning with a mild hp tune for all around driving and towing. I have been considering adding a cold air intake but didn't know if any gains in hp, mpg, or lag on take off would be worth the money spent on the intake if I stay with the tuning I have on the truck now. I have some turbo lag but it isn't terrible compared with what I've read some others post. I read that an intake might help with that, but don't know if that's true or not. I don't do any really heavy towing. Mainly a 30 ft. travel trailer that weighs about 7,000 lbs.
Old 07-30-2014, 02:20 PM
STROKINMY'08's Avatar
STROKINMY'08 STROKINMY'08 is offline
STROKINMY'08 is gaining momentum as a positive member of FTE.
opinions very...most say if your not running big hp tunes then an intake is a waste of time! I run the 250hp setting on my mini maxx ...so I added aFe stage 2.. gained another 28hp/42lbs torque..why not?? The more power the better....You have 2 be careful with intakes because they don't all seal as well as the factory one...really it's up to you!
Old 07-30-2014, 11:56 PM
parkland parkland is offline
parkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud of
I have bought 2 aftermarket air intake products.
1 was a k&n filter that didn't seal right, and would have dusted the engine if I didn't notice.
2 Was a afe intake system, and the rubber boot on the turbo cracked right apart after a week or month or something. Allowing totally unfiltered air in the turbo and engine.
2/2 total piles of crap.
The 6.0 and 6.4 trucks have awesome stock air intakes.
Old 07-31-2014, 06:36 AM
davalt75's Avatar
Thanks for the advice, guys. From what I've read, you don't see any measureable benefit performance wise unless you are running high HP tunes. The tune I have on my truck is a lower HP tune suited for all around driving and towing. I don't care about a big increase in HP anyway. I was just looking for a little more pep to maybe help with the turbo lag issue. Sounds like it's not worth the money or risk of dusting my turbos for a few extra ponies.
Old 08-01-2014, 09:53 AM
Toreador_Diesel's Avatar
Toreador_Diesel Toreador_Diesel is offline
Toreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputation
To each his own, but as a few others have mentioned, if you're running high horsepower tunes, it does indeed help the turbo spool and truck breathe better overall. If you're running stock or not much above stock, there's really no point to it.
I know it's no comparision between a 6.0 and 6.4, but running Gearhead's SRL+, the Atlas 40 FICM, and the stock intake, my truck would smoke heavily when I mashed it at times. This is because it took the turbo longer to spool and clean up the smoke. I replaced the intake with an AFE Stage II SI and noticed much better spooling and way less smoke.
Bottom line: If your truck is belching out smoke, chances are it's not getting enough air and you should consider an intake. If you only see a slight haze or a less than obnoxious amount of smoke, stick with the stock setup.
Old 09-02-2014, 10:26 AM
RM2738's Avatar
RM2738 RM2738 is offline
RM2738 has a very good reputation on FTE.RM2738 has a very good reputation on FTE.RM2738 has a very good reputation on FTE.
One benefit is the ability to clean a cotton filter. It'll take a while to see the break even point on cost, but paying $30-50 for a new OEM filter every 10-20K miles can add up.
Old 09-06-2014, 10:06 PM
mich800 mich800 is offline
mich800 is starting off with a positive reputation.
Was it expensive to have 5 star flash the computer and not purchase a tuner? I assume you do not go to the dealer anymore and if you do how do make sure they don't give you an updated flash and mess you up.
Old 09-07-2014, 06:43 AM
davalt75's Avatar
Quote:
It was $900 for them to remove the dpf and install the replacement pipe, as well as install the blanks in the egr and delete and reprogram the truck. Not sure how much it would be just for them to flash it. Do maintenance myself (oil and filter changes, etc.) so I haven't been to the dealer since the delete.
5 star tuning + k/n cold air intake combo gustrider4 1999 to 2016 Super Duty 9 06-13-2016 10:25 PM
Recommended intake exhaust and tune jahrenholtz 1999 - 2003 7.3L Power Stroke Diesel 16 05-20-2016 08:51 AM
Installed 5 Star tuning thinksnow 2007 - 2014 Expedition & Navigator 14 07-14-2013 02:12 PM
People with a Powermax turbo villestrip 6.0L Power Stroke Diesel 28 03-27-2013 02:14 AM
Cold air intake choices for 6.4L MexicanScaper987 6.4L Power Stroke Diesel 9 08-10-2011 10:13 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
