Cant figure this out
I bought a 2003 Excursion with the 6.0L bone stock a few weeks ago and it drove great for a few days until the CEL came on. I hooked up AE and pulled the codes and all it came up with was P2285 ICP Sensor Circuit Low. So I started looking into things and this is what I have found so far.
Truck Starts fine on first crank maybe 5-10 seconds. Sometimes will have a little stutter for a few seconds after it starts that clears out. Slight puff of smoke at start-up.
Coolant levels have not changed.
ICP: (Don't know why the code is being set with it running like this)
Idle is at about 650-680 PSI
Desired and actual readings are usually 5-15 PSI different
Voltage looks good according to sliding scale for the sensor
Battery Voltage:
Cranking 11.9V
Running 12.9-14V
FICM:
Key off 0V
Key on engine off 48V
Key on cranking 47.5V
Key on engine on 48.5V
Key on accelerating 48V
During the first 10 min of start-up and drive it feels like it will stutter and surge. also will blow a puff of blue smoke when shifting out of first.
I have ran AE and poked around at all of the harness connections and cannot find any loose connections, shorts or chafing that would be making this happen when going over bumps.
Battery Voltage:
Cranking 11.9V
Running 12.9-14V
FICM:
Key off 0V
Battery Voltage:
Cranking 11.9V
Running 12.9-14V
FICM:
Key off 0V
Battery Voltage:
Cranking 11.9V
Running 12.9-14V
FICM:
Key off 0V
Thank you for all the help. I got the sensor swapped out and the new pigtail soldered in on Saturday. All the guides were right on took about 4 hours with breaks. Now I am showing .22V KOEO and no more surging.
Still cant believe that slight voltage variance at startup was causing me that much of a headache even though the PSI reading were right on.
