Labors! - Ford Truck Enthusiasts Forums
Labors!
Old 07-29-2014, 10:57 PM
Ford12006 Ford12006 is offline
Ford12006 is starting off with a positive reputation.
Labors!
I am tring to find out why my F150 Supercrew with a 5.4 and is 4x4 as I start from a stop and I give it gas it shifts from 1st it shifts fine. but when it goes into 2nd gear it starts laboring really bad as if it has no power. If you give it little gas it seems like it has no power. So I decided to push the overdrive button off and it still does the same thing. I have never pulled a trailor in overdrive and it decides to shift automatically into overdrive when I am driving below 45 mph. Please help!!!
Old 07-30-2014, 12:12 AM
70f100longbed's Avatar
70f100longbed 70f100longbed is offline
70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.
Sounds like the cats may be clogged. Loosen the exhaust at the manifolds and see if it runs better
'05 F150 overdrive shifting problem drew_goeke 2004 - 2008 F150 26 11-20-2016 11:16 AM
New Rebuilt E4OD, Has Overdrive cold, No Overdrive After Warm Transam461 1987 - 1996 F150 & Larger F-Series Trucks 7 09-10-2016 12:58 PM
92 F150 Loss of power RSDLOMPOC 1987 - 1996 F150 & Larger F-Series Trucks 0 07-07-2014 01:16 AM
aode transmission overdrive troubles 94GreenTruck 1987 - 1996 F150 & Larger F-Series Trucks 45 03-24-2014 10:26 AM
e40d Auto Trans overdrive LIKENIT 1999 to 2016 Super Duty 2 05-26-2013 05:27 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
