AC pump stops cycling after 15 mins of use
Old 07-29-2014, 10:02 PM
Dutter 2's Avatar
Dutter 2
Dutter 2 is offline
Ok this is actually on my girls car, a 2000 altima. But i know all newer AC systems work the same. Cus its the same set up as my 98 f150. But the AC will work great for the first 15 mins or so then i notice the pump stops working(not cycling on/off) So i turn it off for 5 mins and then it starts working again and i hear the pump engaging, but itll only work for like 5 mins now. Could it be a bad pressure cycling switch or clogged condenser and gettn the AC too hot and it shuts down. Any ideas ?
Old 07-30-2014, 09:13 PM
steve(ill)'s Avatar
steve(ill)
steve(ill) is offline
I would guess you are a little low on gas. Hi and Lo side staballize at about 100 psi when off. When you startup, the Lo drops to about 30 psi and HI goes up to about 200 psi. There is a low pressure cutout that kicks the pumps off if it falls below about 20 psi. If you had gauges on the system, I think you would see that.
Old 07-30-2014, 09:56 PM
newfordy's Avatar
newfordy
newfordy is offline
A/C stops
yes, get or borrow a set of gauges. So you can tell when the compressor cuts out. At Low or High pressures.
If you verify it is a low charge, it went somewhere(leak).
Old 07-30-2014, 11:21 PM
Dutter 2's Avatar
Dutter 2
Dutter 2 is offline
hmm that dos make sense, ill check it out
Outdoors4life
1997 - 2003 F150
12-10-2010 07:36 AM
GMAESTRI
1997 - 2003 F150
05-22-2010 08:41 AM
shinson2
05-29-2009 08:53 PM
tp4pdb
08-17-2008 10:36 PM
96DRW
09-11-2006 11:43 AM
Quick Reply: AC pump stops cycling after 15 mins of use
