what radiator - Ford Truck Enthusiasts Forums
what radiator
Old 07-29-2014, 09:57 PM
69issofine 69issofine is offline
69issofine is starting off with a positive reputation.
what radiator
i have a 69 f-250 with a 300 inline. do i use the radiator out of the 69 or get one out of a 91? the 69 is a downflow with the hoses at the wrong spot and the 91 is a cross flow that mounts different.
Old 08-01-2014, 10:32 AM
trozei's Avatar
trozei trozei is offline
trozei has a great reputation on FTE.trozei has a great reputation on FTE.trozei has a great reputation on FTE.trozei has a great reputation on FTE.trozei has a great reputation on FTE.
How could the radiator built for your truck possibly have the hoses in the wrong spot?
Old 09-04-2014, 12:18 PM
radiator in the wrong spot
the radiator that is in the truck has one fitting on the top on the passenger side and two fittings on the bottom, it was hooked up to go straight through with no cooling effect. As the two fitting on the passenger side is inline with each other it only utilizes half of the radiator,but the cross flow from a 91 the inlet and outlet are opposite of each other making the coolant flow across and out the other fitting that and an electric fan should cool it off better because right now it runs for about five minutes before it starts to overheat. The fittings on the 91 water pump, has the top fitting going towards the center,and the bottom fitting is towards the passenger side i don't know maybe my radiator is toast,I tried to run water through it it seemed to run ok. I know i need a fan shroud but i was thinking of a electric fan i have a radiator out of a 95 windstar to use as a mockup templet it only has two or three tubes broke but it should work for a template.
91 300 in a 67 f250 flat bed 69issofine Engine Swaps 1 09-05-2015 05:20 PM
69 f-250 69issofine 1967 - 1972 F-100 & Larger F-Series Trucks 6 04-27-2015 10:39 PM
69 flat bed 69issofine 1967 - 1972 F-100 & Larger F-Series Trucks 2 07-29-2014 10:09 PM
clutch linkage 69issofine Ford Inline Six, 200, 250, 4.9L / 300 0 07-24-2014 10:33 PM
69 f250 with a 300 out of a 91 69issofine Ford Inline Six, 200, 250, 4.9L / 300 0 07-24-2014 10:13 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
