Help...Flywheel/Crank Locked-up
I started an earlier thread about changing my clutch. Well, after removing/re-installing my flywheel...to change my pilot bearing and RMS...the flywheel and crank are locked-up...I can't turn the crank from the front crank pulley...I'm thinking the flywheel bolts are too long, but their the same ones I took out...do any or all of the bolts take a washer or??
Yes, the clutch and starter are still out...I removed the flywheel to change the pilot bearing and rear main seal (RMS)...I needed to turn the crank for clearance when torquing the flywheel bolts down and it wouldn't turn...it turned before I re-installed the flywheel?? Are there supposed to be washers on the flywheel bolts??
I know that the bolts on my flywheel (on the 4.9 new build) do not have washers. Come to think of it, I haven't tried turning the crank since I installed the flywheel.. Think I'll try that this afternoon...
If you loosen the flywheel, can you turn the crank?
In looking at mine, the bolts would need to be WAY long to lock things up. Did you do anything else? Install the rear main seal?
I'd loosen it up and be 100% sure that is the problem before I started chasing things.
I know you said you are 99% certain loosening it up will allow it to turn. I'm betting it either won't, or in the process of loosening it up you'll figure out the problem.
