1985 F150 302 holley problems - Page 9 - Ford Truck Enthusiasts Forums
  #121
Old 08-16-2014, 05:25 PM
Kyre Searcher Kyre Searcher is offline
Kyre Searcher is starting off with a positive reputation.
Quote:
Originally Posted by Franklin2 View Post
I would be curious how it would react if you turned the mixture out from 1 1/2 turns to 2 turns to 2 1/2 turns.
Don't be afraid to try things. The engine will react and give you clues. Just like putting the rags over the secondaries makes it run, that is a clue you are getting too much air, or not enough fuel. That's why I am curious what would happen if you turn the screws out some.
I will try to go to 2 1/2 out and see what that does. thanks
should i try this with or without the cloth?
  #122
Old 08-16-2014, 05:27 PM
Quote:
Originally Posted by Gary Lewis View Post
What happens if the 2bbl is put back on, just for a test?
As long as I have owned this truck it has always had the 4bbl, I dont own a 2 bbl, would be worth the try if I had one tho
  #123
Old 08-16-2014, 06:03 PM
Gary Lewis's Avatar
Gary Lewis Gary Lewis is online now
Gary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant future
Probably why he sold it - couldn't get it running right.
  #124
Old 08-16-2014, 06:07 PM
I have owned this truck for years and it ran perfect up till this problem started.
  #125
Old 08-16-2014, 06:11 PM
Gary Lewis's Avatar
Oh yeah, I forgot that. Old timer's disease.
  #126
Old 08-16-2014, 06:19 PM
ArdWrknTrk ArdWrknTrk is offline
pedant
ArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputation
This is why I said you have to be methodical about your diagnosis.
It started here
Quote:
Originally Posted by Kyre Searcher
My truck (1985 F150 302 holley 80457) all at once started idling hard in park, and killing out if put into gear, I thought the choke might have been sticking so I removed the choke thermostat, and installed by instructions a manual choke.
You need to go back and remember what the truck did that day before it wouldn't idle right.
Did you run a tank out of gas?
Did it overheat?
Did you hit a big bump?
Something happened...
It could be many things, but the truck is trying to give you clues.
You need to stop messing with a dozen different things and figure out why it is running lean.
We're now on page 9 and none of the usual suspects has a clue...
  #127
Old 08-16-2014, 06:29 PM
Gary Lewis's Avatar
I'm an un-usual suspect and I'm totally lost. I recommend one FTE'r guide things and the rest sit out. Maybe we can get some focus. I'm done, over to whomever. (It ain't me, babe! It ain't me you're looking for, babe. No! No! No, it ain't me, babe!)
  #128
Quote:
It started here
Did it overheat?
the day this started, I drove it on break, I came up where a dirt road meets paved road, the dirt road was rutted but not severely , but enough to drive at idle speed. the switch from dirt to paved is an incline and rough bumps, so the truck always rocks hard left and hard right just as it meets pavement.
it still drove fine till it was parked. next start up was rough idle and stalling in gear
  #129
Old 08-16-2014, 07:37 PM
lol wow mr. jung, your concepts are very interesting, but the line you crossed was real, and the plants you brought with you were illegal..
Blow?
anyway, I had forgotten about the dirt road and the ruts! and I am very sorry this has went into 9 pages, I would have rather it didn't as I am sure you guys feel the same.
Could the ruts and bumps have a play in this?
  #130
Old 08-16-2014, 10:04 PM
Patrick Omally Patrick Omally is offline
Patrick Omally is starting off with a positive reputation.
Quote:
Blow?
if you disconnected and capped (with real vacuum caps) all of the vacuum lines, then I cannot think of how ruts and bumps could have played a role in this anymore.
vacuum gauge and fuel pressure gauge are the only thing i can think that will help track down the problem, assuming there are absolutely no vacuum leaks
only thing to do without gauges is to spray around the intake manifold gasket with carb cleaner to check for leaks, and when the engine is running, (with or without cloth) introduce a vacuum leak so we can know if it is running rich or lean. (if it goes faster with a vacuum leak, then it is running rich)
take care
  #131
Old 08-18-2014, 01:22 PM
take care
OK, I have a few pics of the bottom of the carb I wanted to get an opinion on, I took a few thinking maybe one will show more than the other, and a pic of the fast idle as well as idle screws. If this all looks ok, then I am going to replace and try again, this time I will introduce a new vacuum leak as you stated and report on that.
<a href="http://s1375.photobucket.com/user/Kyre_Searcher/media/CAM00517_zpsaf923369.jpg.html" target="_blank"><img src="http://i1375.photobucket.com/albums/ag447/Kyre_Searcher/CAM00517_zpsaf923369.jpg" border="0" alt=" photo CAM00517_zpsaf923369.jpg"/></a>
<a href="http://s1375.photobucket.com/user/Kyre_Searcher/media/CAM00515_zps23cc38c5.jpg.html" target="_blank"><img src="http://i1375.photobucket.com/albums/ag447/Kyre_Searcher/CAM00515_zps23cc38c5.jpg" border="0" alt=" photo CAM00515_zps23cc38c5.jpg"/></a>
<a href="http://s1375.photobucket.com/user/Kyre_Searcher/media/CAM00518_zps97e2026a.jpg.html" target="_blank"><img src="http://i1375.photobucket.com/albums/ag447/Kyre_Searcher/CAM00518_zps97e2026a.jpg" border="0" alt=" photo CAM00518_zps97e2026a.jpg"/></a>
<a href="http://s1375.photobucket.com/user/Kyre_Searcher/media/CAM00520_zps6e37b166.jpg.html" target="_blank"><img src="http://i1375.photobucket.com/albums/ag447/Kyre_Searcher/CAM00520_zps6e37b166.jpg" border="0" alt=" photo CAM00520_zps6e37b166.jpg"/></a>
  #132
Old 08-18-2014, 02:00 PM
In the pic above, the primary looks like it is dented or something, but it is not, just some weird reflection, but here is a pic of the converter plate, from 4 to 2 bbl, is it possible this plate is upside down? holding the secondary's in the wrong position?
  #133
Old 08-18-2014, 02:04 PM
pedant
Hard to tell from your second photo, but your secondaries look way too open..
(I'm on my phone)
I can't see the pic in your second post.
The throttle stop screw has an air gap.
This should never be the case.
The throttle stop is to set curb idle speed, the engine should die if it is off the stop.
  #134
Old 08-18-2014, 02:13 PM
(I'm on my phone)
Ok, I am going to close the secondary's more and post post pics, and seat the curb idle to throttle, will update again.. Thanks
  #135
Old 08-18-2014, 02:23 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
Adjust those mixture screws too.
Autolite 2100 - Fast Idle yabadaba 1967 - 1972 F-100 & Larger F-Series Trucks 8 05-15-2016 10:29 AM
300 i6 idle problems mrmauser303 1967 - 1972 F-100 & Larger F-Series Trucks 21 04-23-2016 02:41 PM
Carb Issues csherrill 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 62 09-18-2015 03:36 PM
Holley 4160 won't idle below 900 wyckedcombo17 1973 - 1979 F-100 & Larger F-Series Trucks 11 08-15-2014 06:25 AM
Holley electric choke question okie72 1973 - 1979 F-100 & Larger F-Series Trucks 4 01-29-2014 09:08 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
