1985 F150 302 holley problems - Page 11 - Ford Truck Enthusiasts Forums
  #151
Old 08-18-2014, 05:44 PM
Kyre Searcher Kyre Searcher is offline
Kyre Searcher is starting off with a positive reputation.
Quote:
Originally Posted by Patrick Omally View Post
are all 8 cylinders sparking?? a spark plug inline tester would be great here
it could have even produced the problem in the first place
yes, the plugs seem to be good, but only based on the fact that it runs very smooth and nice if I stuff a cloth into the secondary barrels and adjust the cloth a tiny bit to allow small amounts of air. when its running that way the engine sounds great.
  #152
Old 08-18-2014, 05:58 PM
Patrick Omally Patrick Omally is offline
Patrick Omally is starting off with a positive reputation.
Quote:
mmmmm not saying much. My 4.9l inline 6 ran pretty good with 2 intake rocker arms missing pushrods. It sounded great when running fast though:P
  #153
Another question just to be clear, the throttle cable connected to the linkage, when the cable is relaxed should the linkage plate be opened at all or completely shut?
At idle the plates should be cracked open a bit correct?
  #154
Old 08-18-2014, 06:24 PM
Quote:
Originally Posted by Franklin2 View Post
It slowed down and died when he pulled a vacuum line off. I believe this is confirmation what we already know, he is lean. I do not know what his aversion is to those two mixture screws, but he simply refuses to move them out some.
I set the mixture screws at 1 1/2 out from seat, then was asked to move out to 2-2 1/2, after doing this no changes were noticed in the running
and when I pulled the vacuum plug off and it died, that was with the cloth in the secondary's, without the cloth the idle got faster when pulling the same pcv plug
  #155
Old 08-18-2014, 06:38 PM
if it can run without cloth remove cloth completely from now on
the cloth was only to get it running
  #156
Old 08-18-2014, 06:47 PM
OK, right now, I can get it running without the cloth in the secondary's, I turned the mixture screws out to 2 1/2, would start then die, I turned both out to 3, and it starts but runs rough in idle and dies in gear..
while it was running, I turned the drivers side mixture screw all the way in, it didnt change anything at all, I then turned it back out to 3 turns and did the same to the passenger side, as the passenger side mixture screw got to about 1/2 a turn out the engine started dying.
I turned it back out to 3 and started it and just let it run to temp with rough idle..
should both mixture screws act like the passenger side screw? drivers side screw did nothing to change the idle at all.
  #157
Old 08-18-2014, 06:49 PM
set screws to 1 3/4 and try again? start with choke, then ease off the choke after about a minute?
  #158
Old 08-18-2014, 06:55 PM
ok 1 3/4 with choke, be right back
  #159
Old 08-18-2014, 07:17 PM
set mixture scews to 1 3/4 with choke, engine starts at around 1500 rpm, choke starts to open and it sputters and dies
  #160
Old 08-18-2014, 07:25 PM
........ and i was hopeful too
the fact that it runs when starting is good... if there was a vacuum gauge we could see if an intake is sticking or open
  #161
Old 08-18-2014, 07:38 PM
while doing this, I did notice that when its running and I touch the throttle linkage the engine revs in slow drawn out spurts, if I push the linkage to rev it, it will rev but idles back down long after I have released the linkage, by long i mean about 3 seconds after letting go of the linkage.
I have a tune up kit coming with vacuum and fuel pressure gauge dist cap rotor and plug wires, only bought it for the gauges but cant hurt to add the rest while im not driving.
  #162
Old 08-18-2014, 07:52 PM
Good work the gauges! i know sometimes gauges cost mega money but at this point they will really help to figure this out and fix it for good!
about the linkages.... how were the mixture screws when you did this? how was the choke? was the cloth still blocking secondaries?
  #163
Old 08-18-2014, 07:57 PM
Idle mixtures were 1 3/4 out from seat, choke was open and no cloth in the secondary's.
  #164
Old 08-18-2014, 09:21 PM
It was able to run without the choke?
How To Adjust The Idle Mixture On Holley Carbs - Blogs - Holley Performance Products Forums
It should be able EASILY to idle with "1 3/4" idle mixture screws without choke. That is what is confusing me so much. It might take 3-4 minutes to warm up, but it should able to idle without choke eventually.
Once it idles w/o choke and w/o rags then everything else is simple to adjust a bit here and a bit there. ofcourse this doesn't mean it will always be able to idle the minute choke turns off automatically. My 4.9liter inline 6 takes 4 or more minutes of high rpm to warm up enough to actually idle normally, it has always needed this time to warm up enough. I have to mash the gas pedal for a few minutes until i feel it has warmed up enough. No it isn't optimal, and yes fast cam should be set higher but it works correctly once warmed up.
  #165
Old 08-18-2014, 09:26 PM
Its to dark to do anything else tonight, but tomorrow I am going to try this and see if the adjustments will help, Im sure the first problem is still present, but once I can get the carb to work right, maybe the other problem will be much easier.
I am going to keep the manual choke handy cause it might be a better option with my truck.
Autolite 2100 - Fast Idle yabadaba 1967 - 1972 F-100 & Larger F-Series Trucks 8 05-15-2016 11:29 AM
Carb Issues csherrill 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 62 09-18-2015 04:36 PM
Holley 4160 won't idle below 900 wyckedcombo17 1973 - 1979 F-100 & Larger F-Series Trucks 11 08-15-2014 07:25 AM
78 Stalled truck..just finished carb rebuild moonshine34 1973 - 1979 F-100 & Larger F-Series Trucks 6 06-09-2013 10:23 AM
going from 2 barrel to 4 barrel electric choke issue gtuttle 1973 - 1979 F-100 & Larger F-Series Trucks 8 05-27-2010 09:15 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
