1988 f super duty?
Old 07-29-2014, 09:25 AM
kurtis1971's Avatar
kurtis1971
kurtis1971 is offline
1988 f super duty?
I just got one and am shocked at how heavy its built. I can't find much info on it though. Any info would be appreciated.
Old 07-29-2014, 10:36 AM
GarageSupervisor's Avatar
GarageSupervisor
GarageSupervisor is offline
These are built like tanks but they got delivered stripped often, 4x2s (except some that were modified) and a mix of gas and diesel. Post a VIN and I'll give you lots of details.
Old 07-29-2014, 04:53 PM
tjc transport's Avatar
tjc transport
tjc transport is offline
i ain't rite
Received 3,078 Likes on 2,148 Posts
all F-superduties were delivered from the factory as 2 wheel drives.
there were a few companies that did 4 wheel drive conversions on them , the most popular probably was Marmon-Harrington.
you can pretty much get anything you need for the truck by asking for parts for an 88 F-350, except for the rear axle and parking brake assembly. that is a dana 80, and has either 4.56, 4.63, or 5.13 gear ratios.
Old 07-29-2014, 10:39 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
FORDF250HDXLT is offline
The F-Super Duty 1987-97 (the original super duty prior to '99 pickups) was introduced to bridge the gap from the F350 to medium duty trucks. It was a commercial cab & chassis 2WD dually only optioned truck.
Known at the time as the "One Ton Plus." It sports a HD frame,the hydroboost brake system w/ 4 wheel disc brakes.Though they are 2WD trucks,they are equipped with 4WD transmissions but,rather than a transfer case,they come with a drive line emergency/parking brake. A HD dana 80 rear axle that came from ford with gear ratio options intended for two purposes; heavy hauling & towing.They came in various wheelbase lengths with up to a 15,000 LB GVWR.It's widely known as the F-450 equivalent with many auto stores listing parts under either name.
These trucks are easy to spot with their pickup size cabs,yet unique F-Super Duty fender emblems & 10 lug wheels.
axle code 72 = 4.63
axle code 73 = 5.13
Old 07-30-2014, 12:28 PM
kurtis1971's Avatar
kurtis1971
thanks for all that info
Here is the vin #2fdlf47g4jcb13803. I hope that helps. I need to find a repair manual. also if someone knows where to look.
Old 07-31-2014, 05:52 AM
kurtis1971's Avatar
kurtis1971
I need a banjo bolt for the brakes but no one seems to have any.
Old 07-31-2014, 06:14 PM
FORDF250HDXLT
Dorman 13947 ?
DORMAN Part # 484188 for the washer.
(according to rock auto and amazons part finder.)
Old 07-31-2014, 08:12 PM
SuperDutyScaler's Avatar
SuperDutyScaler
SuperDutyScaler is offline
Enjoy your real Super Duty! A truck when Ford still made TRUCKS, my buddy has a 1995 F450 and compared to my 2004 F350 its makes my truck feel like a F150
galaxy S4 using IB AutoGroup
Old 08-02-2014, 03:11 PM
GarageSupervisor
kurtis1971,
2FD - Ford Motor Company of Canada
L - GVWR 14,001 - 16,000 lbs
F47 - Super Duty
G - 7.5L
J - 1988
C - made by our Canadian friends in Oakville (Ontario)
These trucks can (and often do) last a lifetime. I'd suggest you invest in some good Ford service manuals readily available on the internet for pennies on the original dollar.
mdh1701
05-04-2014 04:02 PM
compsec
05-04-2014 03:11 PM
ewoods8393
12-26-2013 10:02 PM
Bad 674x4
05-01-2013 03:02 AM
truckdriver_mn1984
04-28-2009 03:15 PM
Quick Reply: 1988 f super duty?
