1988 f super duty? - Ford Truck Enthusiasts Forums
1988 f super duty?
Old 07-29-2014, 10:25 AM
kurtis1971 kurtis1971 is offline
kurtis1971 is starting off with a positive reputation.
1988 f super duty?
I just got one and am shocked at how heavy its built. I can't find much info on it though. Any info would be appreciated.
Old 07-29-2014, 11:36 AM
GarageSupervisor's Avatar
GarageSupervisor GarageSupervisor is offline
GarageSupervisor is starting off with a positive reputation.
Quote:
These are built like tanks but they got delivered stripped often, 4x2s (except some that were modified) and a mix of gas and diesel. Post a VIN and I'll give you lots of details.
Old 07-29-2014, 05:53 PM
tjc transport's Avatar
tjc transport tjc transport is offline
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
all F-superduties were delivered from the factory as 2 wheel drives.
there were a few companies that did 4 wheel drive conversions on them , the most popular probably was Marmon-Harrington.
you can pretty much get anything you need for the truck by asking for parts for an 88 F-350, except for the rear axle and parking brake assembly. that is a dana 80, and has either 4.56, 4.63, or 5.13 gear ratios.
Old 07-29-2014, 11:39 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT FORDF250HDXLT is offline
FORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant future
The F-Super Duty 1987-97 (the original super duty prior to '99 pickups) was introduced to bridge the gap from the F350 to medium duty trucks. It was a commercial cab & chassis 2WD dually only optioned truck.
Known at the time as the "One Ton Plus." It sports a HD frame,the hydroboost brake system w/ 4 wheel disc brakes.Though they are 2WD trucks,they are equipped with 4WD transmissions but,rather than a transfer case,they come with a drive line emergency/parking brake. A HD dana 80 rear axle that came from ford with gear ratio options intended for two purposes; heavy hauling & towing.They came in various wheelbase lengths with up to a 15,000 LB GVWR.It's widely known as the F-450 equivalent with many auto stores listing parts under either name.
These trucks are easy to spot with their pickup size cabs,yet unique F-Super Duty fender emblems & 10 lug wheels.
axle code 72 = 4.63
axle code 73 = 5.13
Old 07-30-2014, 01:28 PM
thanks for all that info
Here is the vin #2fdlf47g4jcb13803. I hope that helps. I need to find a repair manual. also if someone knows where to look.
Old 07-31-2014, 06:52 AM
I need a banjo bolt for the brakes but no one seems to have any.
Old 07-31-2014, 07:14 PM
Dorman 13947 ?
DORMAN Part # 484188 for the washer.
(according to rock auto and amazons part finder.)
Old 07-31-2014, 09:12 PM
SuperDutyScaler's Avatar
SuperDutyScaler SuperDutyScaler is offline
SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.
Enjoy your real Super Duty! A truck when Ford still made TRUCKS, my buddy has a 1995 F450 and compared to my 2004 F350 its makes my truck feel like a F150
galaxy S4 using IB AutoGroup
Old 08-02-2014, 04:11 PM
kurtis1971,
2FD - Ford Motor Company of Canada
L - GVWR 14,001 - 16,000 lbs
F47 - Super Duty
G - 7.5L
J - 1988
C - made by our Canadian friends in Oakville (Ontario)
These trucks can (and often do) last a lifetime. I'd suggest you invest in some good Ford service manuals readily available on the internet for pennies on the original dollar.
Info center retrofit X-ford Excursion - King of SUVs 3 08-07-2015 08:47 PM
New here blazerboat New Member Introductions 0 07-04-2015 02:44 PM
upgrade info waylove 6.0L Power Stroke Diesel 8 04-17-2015 09:11 PM
VIN info. on my 2009 F-350 cmh144 1999 to 2016 Super Duty 7 10-08-2014 01:37 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
